Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
230/225 2003 Auto with Headers
Old Jun 9, 2007 | 02:40 PM
Snolife's Avatar
What we have here is a failure to communicate
The first two are from when I had my y pipe only with the cattback.
And this one is with the newest Cattman headers with Cattman cattback and fastcat and my Emanage Ultimate tuned that was done today.
I forgot to grab the a/f one, suppose to get it emailed to me tonight. I will put that up once I get it. Let me know if I made a mistake on the tq. figure. Just learning how to read these things and I will correct it, thanks.
Old Jun 9, 2007 | 03:13 PM
nismology's Avatar
Those graphs are absolutely useless but nice numbers.
Hmmmm...I guess the last two aren't so bad.
Old Jun 9, 2007 | 05:13 PM
speed racer's Avatar
make sure get the run files. Did you remove the shelf on your IM. Seems like the torque drops off quick after 5000 rpm
Old Jun 10, 2007 | 04:02 PM
NmexMAX's Avatar
dot dot dot ...
Dynapack runfiles?
Old Jun 10, 2007 | 06:51 PM
steven88's Avatar
Need A Light?
Nice Numbers Gary
Old Jun 10, 2007 | 10:24 PM
Theyears02's Avatar
does a dynapack run high or low? nice numbers, but hard to use/read graphs
Old Jun 10, 2007 | 10:40 PM
steven88's Avatar
Need A Light?
it reads higher than usual...a mustang dyno reads lower than usual
Old Jun 11, 2007 | 06:12 PM
Snolife's Avatar
Working on the run files.
Old Jun 13, 2007 | 09:23 PM
michaelnyden's Avatar
nice #'s gary...! did sean do the tuning himself? what a/f ratio did he tune for as a target? and did you add any ignition timing? if so, care to share any of the tables from your EU...? or th file itself?
Old Jun 14, 2007 | 06:18 PM
Snolife's Avatar
Im still waiting on the run files. I guess I need some viewer to view them? Can someone shed some light on this for me? Thanks. Here the a/f one. Im sure all of you understand this better then I do.
Old Jun 14, 2007 | 07:55 PM
NmexMAX's Avatar
dot dot dot ...
Typically, Dynojet runfiles are widely used around here. I have yet to hear of DynaPack runfiles.
Old Jun 14, 2007 | 08:22 PM
I believe they are just excel spreadsheets or comma seperated files with the #'s in them when it is a dynapack...
Old Jun 15, 2007 | 04:55 AM
Your a/f is all over the place it should be closer to 13.5. Your too lean.
Old Jun 15, 2007 | 09:19 PM
steven88's Avatar
Need A Light?
He has a catalytic converter...and the dyno shop used a tail sniffer
Old Jun 15, 2007 | 09:36 PM
I c. yea than it would be leaner. You need a test pipe with a wide band 02 than.
Old Jun 25, 2007 | 09:54 AM
NmexMAX's Avatar
dot dot dot ...
Or a wb for said wb before the main cat.
Mahmuth
Aug 16, 2024 08:23 PM
BobTX10
Oct 7, 2015 08:43 AM
dshinn
Sep 26, 2015 08:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
