Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Another dyno!
Old Oct 22, 2007 | 12:02 AM
95BLKMAX's Avatar
Another dyno!
So I went back to the dyno this weekend.
This is a comparison of my best dyno from last month, to that of this weekend.
Things new for this dyno... "jdm" headers with custom equal length ypipe, ubber short intake (no midpipe).
I was somewhat disappointed that its mostly the same thing! Peak #s are now 243.5whp (244dammit! :-D)/ 237wtq.
Then I looked closely at redline. Notice how at redline I gained 10whp and 9wtq!!! Of course at the stock redline thats caca, since the gain starts right at the fuel cut basically, but keep in mind I'll soon be reving this motor to 7000-7200. So a 10whp improvement at the stock redline sure will add area under the curve for that extended redline.
Here's a closer look...
Am I disappointed about the headers? Not that bad. Headers dont do that much over the stock headers in NA form, so I wasnt expecting much. But from what Ive learned, long-runner headers sure love dem some ignition timing advance. the conjunction of the two makes for much better results rather than one by its own (they complement each other in that sense). Same as an ubber short intake/ 3" MAF/ SSIM all work together to make that top end ubber.
One thing I must say about the headers tho, even if they didnt make any big power (for now) over stock headers with WSP ypipe... the SOUND alone is worth it all! Yooooooo, my car SOUNDS like a Z33 on roids! Hopefully gtr_rider will chime in about it- he was standing next to me behind the car. Wow it sounds amazing! If you dont have EQUAL LENGTH HEADERS, be it Hotshots, Cattmans, or custom rigs like mine.... you DO NOT have REAL headers :stfu: lol.
So I cant wait for that EU. GoalieKeg my friend!, Eddy requires that ubber PnP harness :-D please! :-D
Old Oct 22, 2007 | 06:14 AM
SonicDust187's Avatar
Nice numbers. However, is it me or you are preaty lean across the board? Can you get a close up pic of your a/f graph!
Old Oct 22, 2007 | 08:44 AM
meximax's Avatar
SC Overspinning Swapper!!
Good power 95BLKMAX and thanks for spending the dyno time (and $) to show us how well individual mods perform. It will be interesting to see how well the power is held past redline. I will be waiting for that dyno with EU.
Old Oct 22, 2007 | 09:01 AM
95BLKMAX's Avatar
Remember this is a sniffer wideband, which always read leaner than true a/f- from my experience by about 0.4:1 leaner. So really if you see 13.9:1, its actually more like 13.5:1 for example.
Thanks MexiMax, neither can I
Old Oct 22, 2007 | 09:07 AM
streetzlegend's Avatar
nice numbers man. i shoulda gone but it was too far just to go watch lol. btw ur turning into a dyno queen lol. all you need is a supra lol.
Old Oct 22, 2007 | 09:48 AM
95BLKMAX's Avatar
meh... increasing dyno #s seems to be easier than decreasing track times . Plus, if my #s on the dyno go up, all else constant, the track times will go down. Sooooo since I have 3 dynos within 1/2 hr from my house, and the track is 1.5 hrs away, yea I do spend more time on the dyno, LOL
Old Oct 22, 2007 | 09:52 AM
What do you use for tuning? Can you make that a/f line straighter? It should help make more power.
Old Oct 22, 2007 | 09:58 AM
nismology's Avatar
That only applies if you have a cat installed.
Old Oct 22, 2007 | 10:02 AM
nismology's Avatar
Good showing my dude. Eager to see what it does with the EU.
Old Oct 22, 2007 | 10:08 AM
95BLKMAX's Avatar
Oh yea??? oh well its still within a safe margin. NMexMax has tried doing low 14s a/f and no pinging, but thats pushing it to me.
Sonicdust, Im using an SAFC1. I cant really get it any straighter than that, as I only have 8tuning points in 500rpm increments from 3000 to 6500.
EU will sort this out.... when I get it, lol
Old Oct 22, 2007 | 01:19 PM
NmexMAX's Avatar
dot dot dot ...
Considering the resolution of that AFR, I'd say you're doing your best with what you have. I go that lean because it's been safe so far, and it does add timing indirectly. ( ). If I had means to directly control timing, I don't think I would go that far.
Old Oct 23, 2007 | 09:39 AM
95BLKMAX's Avatar
exactly. Engineering style, gotta do the best you can with the material you have been given, and make it work, lol.
Old Oct 23, 2007 | 09:43 AM
NmexMAX's Avatar
dot dot dot ...
Being resourceful FTW.
But honestly, these cars are picky, so no one correction will mean the same 2 AFR’s for a given RPM in 2 separate ‘runs’. That is also the disadvantage of ‘tuning’ with the MAF. So, like I said, Sonicdust needs to pay more attention to the resolution you used in order to really see how flat of a line it is. I’ve street tuned many times and dynod about as many times, and no 2 dyno runs/street run AFR’s will be the same, EVEN when using the EXACT unchanged correction% maps.
Old Oct 23, 2007 | 09:57 AM
gtr_rider's Avatar
192.168.1.1
Yup, the car sounds like a monster Z33 from the back puts out the numbers also.. cant say the same for myself though.. LOL
Old Oct 23, 2007 | 10:08 AM
I dont need to pay attention to anything. I know that it will look worst the more resolution you have on the graph. However, using a SAFC to tune is crap and it doesn't have the resolution to make the whole graph as smooth as can possibly be had. Btw I do know that no 2 dynos will produce same readings.
Old Oct 23, 2007 | 10:55 AM
ajcool2's Avatar
Sound Clips or :ban:.
Nice numbers.
Old Oct 23, 2007 | 11:36 AM
NmexMAX's Avatar
dot dot dot ...
Lighten up Jesus.
My point was that it’s difficult to get a smooth line, no matter if you’re using a SAFCI, SAFCII or VAFCII. Yes, it’s crap, but it’s all some of us have right now, and is certainly better than nothing.
I can do OK with the SAFCII.
Old Oct 23, 2007 | 12:50 PM
jmeister's Avatar
Nice numbers
I'd say throwing some timing to it between 3000 and 4500 RPM w/ the EU will really straighten that torque curve for you.
In for some sound clips too!
Old Oct 23, 2007 | 03:27 PM
95BLKMAX's Avatar
great, so now I have to get sound clips .
streetz! Lets go have some highway fun with the camera :-D.
Sonic, when NMexMax refered to the resolution I dont think he was refering to the resolution of the graph, but the resolution of the AFC (amount of points). Its def like the bare bones of AFCs (I have the SAFC-1, lol) but like he said, its better than having nothing at all, certainly has gotten the job done for the last 2 years that I've been rocking it. But yea EU is way beyond it.
Jmeister, (nice username btw, lol. Not a fan of Jagger, but it does taste good with Red Bull ) funny you mention advancing timing.
Last nite I wanted to do some logging with streetz laptop and we decided to try out if the timing corrections would work or not. It is adjustable from -15* to +15*. We did a 2nd gear pull with normal ECU timing, then we did +5* and did another 2nd gear pull... It pulled ALMOST as hard as E55AMG's old Max, streetz and me looked at each other like....
daaaaaaaaaaaaaaaaaaaaaaamn!!!!!!!
Those RPMs flew to redline and w got pined to the seats like woah, felt like streetz car when it spools up, insane, lol. And that was just on +5*
Old Oct 23, 2007 | 04:18 PM
jmeister's Avatar
Timing corrections with what?
Old Oct 23, 2007 | 04:51 PM
95BLKMAX's Avatar
Sorry, its an OBD2 scanner program, Nissan Data something. It has most diagnostics, has an option to monitor just about anything on the ECU, and it can also, advance/retard timing, turn off individual coils, the fuel pump, etc... Of course the changes arent permanent thanx to our ROM-only ECU.
Old Oct 23, 2007 | 04:55 PM
gtr_rider's Avatar
192.168.1.1
i think we need to hook that up to mine and see what it do
Old Oct 23, 2007 | 05:17 PM
95BLKMAX's Avatar
blah, no sound clips til next week. Time restraints
Old Oct 24, 2007 | 09:33 AM
95BLKMAX's Avatar
Alright, News flash. This dyno I went to now has an ubber special for the rest of the year... means you guys are gonna see alot of dynos from the South Florida Maximas, lol.
Im goin next week with streetz and his laptop. I already have a baseline, so no need for stock timing run. Its gonna go like this...
#1= +5* advance
#2= +8* advance
#3= +10* advance
Thing about this OBD2 program that we'll be using for my timing adjustments isnt so refined as an EU lets say. It will input the timing corrections I select over the ECU's timing, so if I select +8* advance, its going to advance the entire timing curve by +8*. So lets see how my torque peak likes those +8* and +10* added ontop, lol.
Should be interesting! And yes, soundclips will come from this FTW
Old Oct 24, 2007 | 09:42 AM
hmmmm, I predict a high 250's whp hopefully we dont experience any knock.
Old Oct 24, 2007 | 09:45 AM
95BLKMAX's Avatar
nothing that a few bottles of methanol in the gas tank cant solve , plus I'll make them wait til engine temps drop to 180* before doin a pull, lol. Should be fine *i hope, lol*
Old Oct 24, 2007 | 03:04 PM
NmexMAX's Avatar
dot dot dot ...
Ok wait… You already got the EMU installed? Ahh, GK’s unit w/harness?
Old Oct 24, 2007 | 09:02 PM
95BLKMAX's Avatar
Nah man I wish!!!! Its gonna be with this OBD2 program on streetz laptop. (refer to post #19 and #21)
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Chebosto
Dec 19, 2001 06:34 AM
Nismo87SE
Oct 23, 2000 08:15 AM
