Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
I’m proud to be part of the 300 horsepower club! :oD
Old 03-03-2008, 06:44 PM
Licensed to Spell
ptatohed's Avatar
Guys, please excuse my double post. I couldn't choose just one forum to post in. Thanks for understanding.
Exact duplicate post in the SC/TC forum.
Copy and paste:
I went to the “Dyno Day” at Dyno Extreme on Sunday, 03-02-08 in Stanton CA (near Knott’s Berry Farm in Buena Park) with James / The Wizard. It was nice to meet up with Joe (joebangaa) and Mike (VIPMaxima, banned, ). Good job guys on your dynos by the way.
It was a fun time. Lots of high horsepower Supras and other cars. Lots of food, snacks and drinks. Bikini car wash, etc.
Well, I got my highest horsepower to date! 322.76 HP and 307.82 TQ.
Last year I was around 240. So, with an 80+ HP increase, I’m quite stoked, to say the least.
A HUGE thanks goes out to Jimbo “The Wizard” Ozouf for helping me crank out 3 pretty big mods in just the week before the dyno.
Total (power) mods and variables are as follows:
Un-tuned
Unless I say otherwise below, I have all OEM parts and the “stock” parts that come with the Stillen SC kit (yes this means: stock injectors, stock MAF, standard Vortech FMU with 8:1 disc, Bosch bypass valve, stock fuel pump, etc.)
One-step colder NGK platinum plugs gapped to 0.037”
91 Octane gas
13.7 lb 17” rims
12.5 lb 12.2” rotors (stock are 15lb ea.)
Cattman cat-back
LSS test pipe (just for dyno and track days)
Warpspeed Fed Spec aluminum Y-Pipe
Fed Spec. left bank manifold (from Fanaticrock – thanks man!)
(I did a CA spec --> Fed Spec left exhaust bank manifold conversion which eliminated the huge left bank pre-cat. I installed a Cattman O2 simulator for the two downstream O2 sensors)
Vortech V2 supercharger, freshly re-built
2.87” Vortech SC pulley (see boost/PSI information below)
Custom intake piping
A 5”d x 8”l PWR water to air aftercooler (barrel design) with a Bosch water pump, a Jackson Racing front-mount heat exchanger, and a Vortech ice chest/water reservoir.
Thermal insulation to protect the underside of the intake tubing from the exhaust manifold/engine heat.
4th gen. Variable Intake set at 5200 RPMs (installed by The Wizard, the VI master)
Freshly rebuilt I30t VLSD automatic transmission (with Hayden #403 cooler)
Perma-Cool oil cooler (not sure if that results in a power increase or not, but, just in case)
I think that’s it. I hope I am not forgetting anything.
Oh, and my I30 fuzzy A, B and C pillars (good for at least 10 HP )
I have a bad memory but I think the mods that are new this time (322HP) from last time (240HP) are: one-step colder plugs, lighter rotors, Cattman catback, Fed. Spec. conversion, re-built blower (which fixed a chipped impeller blade and inlet oil leak), a few more PSI, larger PWR AC which replaced a smaller JR AC (see explanation below), 4th gen. VI, VLSD tranny with cooler, oil cooler. But I did have my fuzzy pillars last time (otherwise I would have dynoed at 230)!
As far as the boost / PSI level... Well, on the dyno I made maximum boost of 10PSI. However, I always hit 12PSI max on the street. The dyno owner/operator told me this was normal and it’s because the dyno has less of a load than the street. Huh?
I recently replaced my small 3”d x 11”l Jackson Racing (JR) water to air aftercooler (AC) with the PWR AC mentioned above. The PWR is supposed to be more efficient in cooling and result in less boost loss. I now lose 1PSI across the PWR AC where before I lost 2PSI across the JR AC. I also have a dual intake temperature gauge by Autometer. I have one probe upstream of the AC and one downstream. With my JR I would see about a 10 degree difference during idling/cruising and a max delta of 40^ during a full boost run. With the PWR I know see a 15-20^ delta when cruising and a 60^ delta during a full boost run. During the dyno, I added ice to the ice reservoir and saw a max delta of 85^!
Dyno Extreme didn’t hand out dyno graphs that day. So, excuse me for the digital camera photo of my dyno. The owner should be sending out the run files via e-mail shortly so I will post up the dyno when I get it. Also, these are the uncorrected numbers.
I’m really stoked. Two of my dreams were achieved at once: 1.) Break 300HP and 2.) Get a single-digit weight to horsepower ratio (~2900 lb / 322 HP = 9.00 LB/HP!!).
ptatohed is offline
Licensed to Spell
ptatohed's Avatar
Pics
ptatohed is offline
Old 03-03-2008, 08:04 PM
dot dot dot ...
NmexMAX's Avatar
IBlearnhowtodynoyourauto Nice numbers man
What wheels are you rockin'?
NmexMAX is offline
Old 03-04-2008, 05:40 AM
03BlkSETE's Avatar
It appears that your car is not level.
Sorry, couldn't help myself, and I know someone else will say if I didn't.
Nice dyno BTW.
03BlkSETE is offline
Old 03-04-2008, 06:43 AM
3.5 in the works
DandyMax's Avatar
Bwah hah ha ... level...
Congrachoomalations on breaking 300!
DandyMax is offline
Old 03-04-2008, 10:28 AM
MorpheusZero's Avatar
Nice, I'm also curious as to what wheels you're running. Those look like narrowish RP-F1s but I don't remember any dipping below 14lbs.
MorpheusZero is offline
Old 03-04-2008, 10:42 AM
Thanatos's Avatar
300+ HP! WOW! man i wouldnt know how to act with that much hp. congrats.
Thanatos is offline
Old 03-04-2008, 12:44 PM
Licensed to Spell
ptatohed's Avatar
Thanks guys.
Yeah, yeah.... the level. I recently ordered a fiberglass hood with an inverse hood scoop and unfortunately the stock shock's bolts don't fit in the hood's holes.
The wheels are 17"x7" Kosei K1 TS.
Tire Rack lists them at 14.1 but I got 13.7 lb on my scale.
I hope this link works.
ptatohed is offline
Old 03-04-2008, 02:48 PM
Turbo 3.5
t6378tp's Avatar
congrat's, I hope to join the club next time I hit the dyno.
any pic's of the hood
t6378tp is offline
Old 03-06-2008, 12:10 AM
Good job Josh! Call Sarkis and bug him for the runfiles...
Can't wait to see your A/F. Time to tune the Max and extract some more ponies...
We should have installed a FP guage under the hood. I bet your FP is getting up there.
The Wizard is offline
Old 03-06-2008, 07:40 AM
joebangaa's Avatar
I wish I stayed to watch your runs..
joebangaa is offline
Old 03-06-2008, 11:58 PM
SpeedCrazie's Avatar
Nice Numbers...Pictures of the Hood?
SpeedCrazie is offline
Old 03-08-2008, 12:23 PM
Licensed to Spell
ptatohed's Avatar
Well, Sarkis isn't sending me the run files on his own so I just sent him a friendly reminder.
As for the hood, I still need to paint it, figure out the hood shocks, modify it a little and so forth, but here is one of the few pics of it I took the night we test fitted it. I am not totally stoked over the looks of it, I just mostly wanted the weight reduction (41.5-20.7 = ~21 lb savings!!) and heat dissipation. It has front inverse hood scoops and a cowl design. The problem is, there is no outlet near the windshield even though it is shaped like a cowl! So I need to cut an opening. Fitment/quality is pretty good other than the hood shock bolt holes being too small and the front passenger corner is lifting a little but I think I can fix both. I'll take more pics when I am all done.
P.S. No, the hood is not closed all the way in this picture.
ptatohed is offline
Old 03-09-2008, 09:21 PM
Z
NYPD-Arnold's Avatar
Damn, that's a 12 second monster.
NYPD-Arnold is offline
Old 03-11-2008, 11:37 PM
joebangaa's Avatar
Josh, have you gotten your runfiles yet? Sarkis lags...
Old 03-12-2008, 12:15 PM
Licensed to Spell
ptatohed's Avatar
I was just thinking about that last night. No, I haven't. I sent a reminder e-mail several days ago - no reply. I'll send one more e-mail and/or call. Have you got yours yet Joe? If you do a drive-by to get yours, could you bug him to send mine? Thanks.
Joe/James, do you have Sarkis's phone number?
ptatohed is offline
Old 03-12-2008, 12:24 PM
Licensed to Spell
ptatohed's Avatar
That's the plan.
Not sure how accurate these formulas are but, if I plug my variables into this formula:
1/4 mile ET (s) = 5.825 x [Weight (lb) / Wheel HP]^.3333
(Weight of car with me = 3150 lb, conservative. FWHP = 300 HP, conservative)
Then: 1/4 mi ET = 12.74 s
We'll see.
ptatohed is offline
Old 03-12-2008, 01:59 PM
714 828 9182 Dyno Xtreme
714 231 4299 Sarkis cell
Old 03-12-2008, 05:36 PM
Licensed to Spell
ptatohed's Avatar
Spank you.
ptatohed is offline
Old 03-14-2008, 10:24 AM
gtr_rider's Avatar
No one else had asked, but whats up with the large section in the charge pipe...
nvm, nice numbers
gtr_rider is offline
Old 03-14-2008, 11:28 AM
Licensed to Spell
ptatohed's Avatar
nvm, nice numbers
I don't think anyone else needs to ask. I clearly stated I have a PWR water to air aftercooler (barrel design, 5" in diameter), talked about it in detail and even included a link to the manufacturer's website.
You read every one else's reply in full but not my first post in full??
Anyway, thanks GTR.
ptatohed is offline
Old 03-14-2008, 12:47 PM
Licensed to Spell
ptatohed's Avatar
I just called Sarkis. I'll get my run files "tomorrow".
Translation: I just made the first of the four total phone calls it's going to take to get him to send the files.
ptatohed is offline
Old 03-15-2008, 08:44 AM
joebangaa's Avatar
I'm starting to get impatient too... I might just stop by...
Old 03-15-2008, 11:05 AM
Licensed to Spell
ptatohed's Avatar
Not a bad idea. Could I trouble you to also grab files 41 and 42 from him please Joe?
ptatohed is offline
Old 03-17-2008, 11:45 AM
Wild for Width
Fr33way™'s Avatar
LOLz I thought I saw a high-flow cat for a sec and then went back to the mod list.
Nice job on the numbers, do you remember what VIP made?
Fr33way™ is offline
Old 03-17-2008, 11:55 AM
whiteonwhite's Avatar
u should put a 3.5 maxima heads on ur engine dis will bring da compression 2 8something2 1 dis way u can turbo da **** out of it but also build lower n top of da block so u dont blow it up
whiteonwhite is offline
Old 03-17-2008, 01:29 PM
VIP made 245hp, but his car and/or tranny were having issues that day. Only hit 7.5psi
Prepare to get eaten alive, as you just walked into the lion's den (referring to Ptatohed's avatar/signature)
And uh.......he's supercharged, so he won't be putting a turbo on it anytime soon.....
Old 03-17-2008, 05:55 PM
Licensed to Spell
ptatohed's Avatar
You have the right to remain silent.
ptatohed is offline
Old 03-17-2008, 06:15 PM
Busted!!
Old 03-17-2008, 08:08 PM
Wild for Width
Fr33way™'s Avatar
Out. Now.
Thanks Wizard, just wondering how things were working out for him. Seems like you guys got the belts down over there, more Code Red!
Fr33way™ is offline
Old 03-17-2008, 09:15 PM
i has college
EnervinE's Avatar
Funniest thing I've seen all day
EnervinE is offline
Old 03-19-2008, 08:36 AM
I love lamp.
maximase86's Avatar
If you don't mind me asking, how much did the PWR cooler run? I assume you can get it so it works with 3" piping like I have?
Great numbers, I'm quite surprised by the torque you're making.
S
maximase86 is offline
Old 03-26-2008, 06:46 AM
dot dot dot ...
NmexMAX's Avatar
Any luck on the DRF's? I'd like to see the plot vs RPM.
NmexMAX is offline
Old 03-26-2008, 07:55 AM
joebangaa's Avatar
Hm didn't realize they changed your X-axis to MPH...I told Sarkis to use RPM early on in the day which they used for my runs...
I still haven't gotten my DRFs either. Maybe if I'm finally not busy this weekend I'll swing by the shop for all of us...
Old 03-26-2008, 12:53 PM
Licensed to Spell
ptatohed's Avatar
S
Hi maxse86. Well, the price I paid isn't that relevant. I did get a really good deal (relative to their MSRP) but keep in mind I already had all the plumbing (hoses, clamps, etc.), the pump and the heat exchanger. You would need the whole kit. Also, PWR is literally 4 miles up the street so I was able to do a 'cash deal'.
They mentioned that they may be able to modify it so that it has 3" ins/outs. It doesn't come that way though.
ptatohed is offline
Old 03-26-2008, 12:55 PM
Licensed to Spell
ptatohed's Avatar
Yeah, I did finally get them. Sorry, I've been busy (body work!) and haven't been to the .org too much. I sent them to The Wizard. He has the program to read them. James, can you post them? Joe, did you get your run files from Sarkis?
ptatohed is offline
Old 03-26-2008, 02:52 PM
Here you go Josh. Your graph is weird. Starts at a little past 4000rpms and ends just beyond 6000 rpms. Nice untuned AFR.
Old 03-26-2008, 03:04 PM
kzoosho's Avatar
Damn you almost as lean as me .
kzoosho is offline
Old 03-27-2008, 06:56 AM
dot dot dot ...
NmexMAX's Avatar
I knew right of way when I saw the speed axis.
NmexMAX is offline
Old 03-27-2008, 11:31 AM
joebangaa's Avatar
Did he email them to you? I have nothing. I'll make sure to stop by DX this Saturday...
Quick Reply: I’m proud to be part of the 300 horsepower club! :oD
