Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
MILD-BUILT VQ35 DYNO BASELINE
Old Nov 3, 2008 | 09:51 PM
95BLKMAX's Avatar
SAE #s
Compares my previous best NA dyno (with catback, it would be unfair to compare it to open cutout as I no longer have a cutout) from Oct07, to the best run of this afternoon. The only things that are different between the two dynos are...
* VQ35HR valve springs double-seated
* Debuloz Ebay JDM cams
* Intake cams clocked to full-retard CVCT position of ~64*
* 3" crush bent catback now (previous was a 2.5" mandrel)
* Emanage Blue now (previously SAFC1)
NOTICE- Although peak numbers dont matter as much as area under the curve (and if you believe otherwise, this thread is too advanced for you n00blet), the gain in peak was pretty nice and more or less as I expected.
PEAK NUMBERS-
WHP= +13
WTQ= -4
However...
AREA UNDER THE CURVE-
Everything under 5300ish is lower now by about 5-7whp, but after that the gain is evident
6000RPM-
WHP= +14
WTQ= +13
REDLINE-
WHP= +25
WTQ= +20
The way these cams- along with the new cam timing, was all put together around the purpose of the motor reving to passed stock to make useable power up there. The decrease in power in the midrange is something I expected.
Driving around it actually feels amazing. Power delivery is very linear and smooth. Everything works great!
Conclusion-
Now that I dyno'd, and tuned, and made sure everything was fine, I can continue on with my All-Motor project as planned... after paying off credit cards and buying a new set of tires LOL. The goal here is to make around 285-290 whp reliably, and so far, this setup is in the right track for it. Dynos will come as mods roll in.
And of course, a video compilation by streetz
http://www.youtube.com/watch?v=mHUbId2qLcY
Thank you all that helped in this project, streetzlegend, Alex, Jimmy, Castellanos, Ernie, and grandp00p!
Old Nov 3, 2008 | 10:14 PM
95BLKMAX's Avatar
BTW, to really hear the loppy idle, if you have a good set of speakers, turn up the bass. "The Rumble" is in the low frequencies. I turned up my bass and you can clearly hear the bouncing around
Old Nov 3, 2008 | 10:35 PM
accordingtou's Avatar
VQ30 DE T
Sweet peak #'s
Your dyno looks like mine.....
Plus 40whp Goodluck with meeting your goals.
Old Nov 3, 2008 | 11:04 PM
JonBlz's Avatar
a.k.a. STuNtMAN
congrats buddy now BOOST IT =)
Old Nov 4, 2008 | 05:16 AM
chillin014's Avatar
too cool man. The gain at redline looks great. Do you think that your running a little too lean still where it starts touching on 14's??
Old Nov 4, 2008 | 06:04 AM
95BLKMAX's Avatar
thanks guys!
Chillin- not really. I used to run 14.1-14.2 all the way with the previous NA setup with no problems. And trust me we added fuel there, it was running ALOT leaner lol. These are my settings for the a/f tuning...
Old Nov 4, 2008 | 06:09 AM
chillin014's Avatar
so you didnt bother making corrections between 25 percent throttle and 90 percent? (or am I reading this wrong). Was it running a little lean at partial throttle down low??
Old Nov 4, 2008 | 06:10 AM
grey99max's Avatar
LandShark has Cosworth
Dude, you do impressive work - especially under tough conditions. Rebuilding the upper end with the motor still in the car - outstanding!
Repeat after me - spray, spray, spray.....
Old Nov 4, 2008 | 06:22 AM
95BLKMAX's Avatar
No need. The adjustment of the Parameter Settings took care of most of it. And then things were fine-tuned as needed on the MAF adjustment table. Driving around its on high 14s, idle is at 14.8-15.0, WOT from lets say 2000 has it at mid 14s then as it gets into 3k it drops into 13s and stays there, just as it would be with working o2s for example.
Thanks grey!
Old Nov 4, 2008 | 06:31 AM
SonicDust187's Avatar
Any reason you haven't upgraded to EU?
Old Nov 4, 2008 | 06:32 AM
95BLKMAX's Avatar
money.
This is just a baseline run to make sure everything is fine before continuing.
Old Nov 4, 2008 | 06:40 AM
How agressive are you going to get with the setup? Bottom end build?
chillin014's Avatar
Yeah, that sounds right (similar to mine)
Old Nov 4, 2008 | 06:49 AM
DandyMax's Avatar
3.5 in the works
So just to clarify.. you clocked the cams to end up at 64* (ie centerline 125) AFTER accounting for the 2* of advance built into the cam? (ie if you install the cams straight up with the dowels flipped 180* you'll get a centerline of 123).
Old Nov 4, 2008 | 06:54 AM
95BLKMAX's Avatar
Ah, thank you! I guess then they are set to 62* . The dowel pins were drilled on the sprockets EXACTLY 180* off stock.
Old Nov 4, 2008 | 07:34 AM
Aaron92SE's Avatar
NWP Engineering.com
Very nice!
Old Nov 4, 2008 | 07:39 AM
liqidvenom's Avatar
brotherhood of tq
very nice, what else are you planing to do on this motor to get to your goals
Old Nov 4, 2008 | 07:56 AM
95BLKMAX's Avatar
well now that I think about it, I thought of my goal #s as STD #s since most of my dynos have been on STD corrected #s LOL. 246whp was my previous best, and this run from yesterday Im showing is about 264whp on STD correction. Anywho, what's next...
- Emanage Ultimate to bump timing and extend redline
- NWP Spacers to bring back some of that midrange
- Polishing and port-matching the LIM, UIM, and Elbow
- Electric Exhaust Cutout (this ALONE on my previous NA setup gained me 10whp)
So one step at a time, we'll see how it goes
Old Nov 4, 2008 | 08:10 AM
liqidvenom's Avatar
brotherhood of tq
Well congrats if i havent said it before. after seeing how much you got done in the span of a week or so i need to stop being lazy. i need to do the following myself:
1) finish tunning my 3.5 and hope to dyno what you put down.
2) fix my extremely dented y-pipe
3) get my iacv installed and my ps issue fixed.
4) install boost.
i'm gonna finish up number 1 this week if it kills me ( well not literally, but you get my point)
Old Nov 4, 2008 | 08:23 AM
chillin014's Avatar
hahah i have one of those too.
yeah 95blkmax is hella inspiring. dont forget about the lightweight flywheel! wont show up on the dyno but it might make 290 feel like 300!
Old Nov 4, 2008 | 08:38 AM
NiZMo1o1's Avatar
sounds really nice !
Old Nov 4, 2008 | 08:44 AM
95BLKMAX's Avatar
4) install boost.
Do it man! I took the days off from both jobs and all to get most of this labor done (of course it rained most of that weekend, so I had to finish it off during the week, LOL). But had been planning this for over a month, so when I got to it I just jumped in and followed my own "to-do check list" lol.
I really want to see what your motor puts down as well! What do you have for tuning? Also, depending on how dented your y-pipe is, it may be a good idea to get that fixed prior to spending the money on dyno-time.
Im somewhat working on that chief, LOL.
Old Nov 4, 2008 | 09:45 AM
nismology's Avatar
I bet you'll see more power if you richen it up to 13.5-13.2:1 with the EU (while of course still maintaining aggressive timing). Good stuff mang.
Old Nov 4, 2008 | 02:15 PM
VqMoNsTeR's Avatar
good job my man. puttin my cams to work!
Old Nov 4, 2008 | 02:27 PM
NiZMo1o1's Avatar
Damn Eddie , I knew that looked like STP , and Rob told me you were up here(just now ), ******* Rob tells me this when I was off all day yesterday sitting on my ***.
If I knew you were up here I would have swing by. Anyways congrats , im telling ya , you can squeeze more out of that motor and im sure you will very soon.
You should have ask them for my runfiles.. I havent been there since I dynoed.
Old Nov 5, 2008 | 07:33 AM
liqidvenom's Avatar
brotherhood of tq
I am hoping to put down at least 240 min. Then i'll make some adjustments and go from there. The y-pipe would be probally an issue and i already have one on order so we shall see when that gets here.
Old Nov 5, 2008 | 08:39 AM
95BLKMAX's Avatar
Thanks b0ss! When the Ej00 comes in, Im gonna crank that timing all the way!
Glad you like what I've done with them, haha. Hey! do you happen to have the actual runfile for when you dyno'd with the cams? I think I asked you this already but I delete my PMs often
Damn! Rob F'ng up! j/k LOL damn man that sucks! Next time I guess then lol. I'll go up there again after either spacers or EU, which ever comes next.
I'll stand by
Old Nov 5, 2008 | 09:56 AM
24K on da way's Avatar
somebody's 3.5 is working flawless
Old Nov 5, 2008 | 05:18 PM
NiZMo1o1's Avatar
Yeah just next time have fgt rob call me ....he always assumes Im working...i aint a ******* robot
Old Nov 7, 2008 | 01:04 PM
NmexMAX's Avatar
dot dot dot ...
Who's the operator? Pansy can't even kiss the limiter.
Old Nov 7, 2008 | 03:49 PM
95BLKMAX's Avatar
it was bouncing off ****! Perhaps if you bought higher quality speakers you would hear it.. I think that black powder from the bombs is getting to your head broah LOL
Nah but if you notice, I've never seen a stock ECU'd 4th gen that will actually let you rev it to 6550, they always stop just shy of it. My car has always done this and all the other 4th gens I've tuned. Only 02+ ECUs let it bounce off to 6600ish.
When is your turn to install those camz? I caught up to you last year! now this is the year for you to make the comeback! With the right parts I KNOW that auto can put down some sexy #s!
Old Nov 7, 2008 | 04:27 PM
NiZMo1o1's Avatar
Hey are you still running a SSIM as well on the above dyno ? And talk about short ram filter.....
Old Nov 7, 2008 | 08:30 PM
95BLKMAX's Avatar
Yup. Its all gutted inside. and yes it is! Got that from NMexMax
Old Nov 7, 2008 | 08:39 PM
MaximaSpd85's Avatar
good stuff, but yo, eddie, man, i thought u had done something bout them taillights?
Old Nov 7, 2008 | 11:53 PM
NiZMo1o1's Avatar
doesnt matter how the tail lights look , thats all your going to see when Eddies pulling a few car lengths..
Old Nov 8, 2008 | 06:42 AM
chillin014's Avatar
umm...
Old Nov 8, 2008 | 07:26 AM
95BLKMAX's Avatar
One day lol
Oh he may have moved to NC meng but he's still SW, j00 no-know guat he got up his sleeve meng! He's got SW-Engineering coming up there
umm...
yea i know
Old Nov 8, 2008 | 01:18 PM
gtr_rider's Avatar
192.168.1.1
LOL, they went from black widow to pink bandit to white ghost.. If it doesnt have duct tape it ain't SW..
Old Nov 8, 2008 | 06:04 PM
NiZMo1o1's Avatar
^^ must be inside joke...
Old Nov 8, 2008 | 08:39 PM
maybe i should have put "LOL"? i dont know
but yeah, ive got that SW blood in me. , duct tape and zip ties FTW
