Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
03 auto dyno IS CRAPPY!!
Old May 4, 2009 | 02:44 PM
  #41
BLACKKILA.GTR's Avatar
also should i elimnate my cat??
Old May 4, 2009 | 02:50 PM
  #42
Originally Posted by Stormzusmc
HAHA , at least your not at 175hp...lulz
lol man im not too way off though..
my boy only made 185 wit almost the same mods
Old May 4, 2009 | 02:56 PM
  #43
Grand_hustle17's Avatar
Originally Posted by BLACKKILA.GTR
the wierd thing is my codes dont stay on all the time.. my cel comes on when my car has been sitting for a while and then the idle kinda acts a lil funny nothing big , just enough for me to notice... for instance the other day the light came on, the next day it went away.. wat in the world could that be... codes comming up is lean bank 1 and 2
knock sensor and evap leak i think is the other one. i have no idea if a close dyno jet by where im at.. mustang dyno in a spot ima be at in cal is charging 350 for a tune. but they said they put some chip in your ecu so ur tune is locked in not too sure about that... also im wondering if i should fix my intake i had to drill a hole to get the vacume hose in there and i dont think it was sealed up right.. so i pretty much deleted that vacume hose put a mini filter on it.. i need some intakes pieces the same size of an injen intake... so i can fix sometings wit my intakesetup...
you might wanna just fix all of em... you dynoed 204whp... you knock sensor is thouwing you off so is all the other problems... chanck you knock sensors and all and you may just squeeze 230whp
Old May 4, 2009 | 03:07 PM
  #44
THATS THE thing the knock senso is new.. i replaced it the day after the dyno
Old May 4, 2009 | 03:25 PM
  #45
i think im most anxious to see your re-dyno... reset your ECU and see what happens
Old May 4, 2009 | 04:24 PM
  #46
q.man06's Avatar
If i was reading correctly, the problem goes away, but the ECU slowly works it's way back to learning how the motor is doing, and advances timing appropriately over some the next several drives. it will pull timing in a hurry, but pushing it back at the motor may take some time.
Get your car running flawlessly before you mod it. Usually mods bring out the car's existing issues like a sore thumb.
Old May 4, 2009 | 10:47 PM
  #47
skidz88's Avatar
keepin you car well maintain, really do help... IDK about and extra 20+whp help but it does... i do also use the highest octane (93) and blah blah's new belts and all that but i truely doubt ill make 240whp... u sir really did set a record... are u gonna post your own thread??? what brand intake, headers and exhaust???... also what size exhaust??
Been super busy but I'll definately make my own thread about it soon.
Old May 4, 2009 | 10:51 PM
  #48
Stormzusmc's Avatar
^^^ why u say that??? who did that???
I did....with my mods i got 175....something is wrong...and running way to lean....i have a thread about it as well...5.5 gen dyno fail...to lazy to link it
Old May 5, 2009 | 12:21 PM
  #49
so wat do i need to do to get tothat point..
spark plugs are brand new
knock sensor- was bought early last year
and the the whole lean in bank 1&2 -- what could cause that problem??
that problem didnt come until i put the spacers in...
Old May 5, 2009 | 05:13 PM
  #50
if the car isnt tuned correctly you could be going through o2 like its no tomorro...
Old May 6, 2009 | 02:10 PM
  #51
still not sure where to start with fixing the problem though
Old May 6, 2009 | 03:29 PM
  #52
have the shop install the new sensors n tune it right there n then
Old May 7, 2009 | 09:35 PM
  #53
To the OP... IIRC dont the SS headers come with EGR??? what did u do with that???
Old May 8, 2009 | 10:52 AM
  #54
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
most headers that come with ports on them for anything (02 sensors or EGR) come with plugs. I'd assume it came with a plug for the EGR port if you aren't using it.
Old May 8, 2009 | 11:42 AM
  #55
THE EGR was plugged up and welded..
Old May 8, 2009 | 04:39 PM
  #56
Old May 8, 2009 | 04:52 PM
  #57
ok im gonna chnage my knock sensor once again...lol any thing else i should look into.. ?>?
where could the lean bank 1&2 thing be comming from
Old May 8, 2009 | 05:00 PM
  #58
i've always had that bank 2 sensor 1 problem with just about all my maxima's except my current... i have no idea, see if the shop can look into it... i never really fixed my problem... Guru's please,
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
