Very Poor 2K2 6MT CM Headers Dyno
Please Help provide feedback or possible solutions for this. Here is the vehicle/mods info. Upfront I want to mention I swapped a low miles (21K) junkyard motor that was sold to me as being from a 6th gen. I have reason to believe it may have actually been a Quest motor if that makes any difference. I did a compression check last night and pulled around 215 across the board (lowest 200, highest 220psi)
2002 6MT: Place Racing CAI / Cattman Headers / 2.5" Y-Cutout / Stock Exhaust / UDP / NWP IM Spacers / Exedy OEM Clutch / 6Gen 6MT Trans / 18" SSR Comp_C Wheels.
I went to dyno my car w/ the above mods on it -- it is very hot today. I went to a domestic shop called HPP - they were pretty friendly, however could not? (or were not willing to?) pull my RPM signal so my dynos have the MPH on the bottom axis (sorry guys.) They also said they couldn't provide the runfiles (I found all this out ofcourse after the car was strapped down..) I had them dyno in 4th gear.
Anyways I went in hoping to possibly hit 240whp? You are about to find out the disappointment I felt.
Here first is a screen shot from wunderground of the weather stats:
I first dynoed 2 runs with the cutout closed, running from cattman headers to straight through pipe to the stock exhaust system. On the third run I crawled under the car and removed the cut-out plate which dumps out right after the headers. Here you see the STD charts comparing the closed cut-out vs open cutout. It gained roughly 7whp throughout the RPM band. 214whp vs 221whp:
Here you will see a chart with the STD#s of the exhaust closed w/ the Air Fuel readings at the bottom (214.2 whp.) The dyno op mentioned my A/F ratios looked good to him and didn't really need a whole lot of tuning - he said it was pretty flat 12.6-12.8 range through the topend.
And finally, here is a chart w/ the SAE #s comparing the closed exhaust 210.1 whp SAE vs Open cutout 217whp SAE.
This is really disappointing to me and I am looking for answers as to why the #'s were so poor. Do the HP curves look like the VIAS is functioning properly?? My freaking stock Altima 3.5 5spd with a K&N flatpanel put down 214whp (at a different shop.)
I'm not 100% certain it is a quest motor b/c when I bought it they advertised it as an '05 6th gen Maxima engine. I just have reason to believe it might be a quest motor instead due to the position of the notch for teh crank position sensor on the upper oil pan not matching up w/ my trans when I swapped the motor in. ( had to swap upper oil pans over from old motor )
Even if it is a quest motor we all know Nissan's HP ratings for the VQ35DE lineup are a mystery at best. See: Reference at end of first post to my stock Altima dyno #'s which is also rated at 240hp from Nissan..
Thanks for your valuable input
I pulled this from the dynojet website for this shop:
High Powered Performance Racing LLC
Model 248x
Model 248x
don't really understand, but the altima is rated at 250hp and 250tq...damn near the same as the max. shouldn't all fwd vq35de's be rated the same? the only way to tell if you are low compared to others with comparable mods is to have someone else strap up to the same dyno that has also been dyno'd at another place and produced more "normal" numbers. it is a dyno, and it is not the end-all be-all for how much power you are putting out....it should be used for tuning purposes only. go get tuned and get back on the same dyno and see what your gains are
if it is your VIAS,... maybe try to buy a block off plate.. and see what kind of difference that makes... IIRC.. they are on sale till midnight tonight...i say try another dyno... one that will give you runfiles and RPM . . .or take it to the track and see what you are trapping
don't really understand, but the altima is rated at 250hp and 250tq... it is a dyno, and it is not the end-all be-all for how much power you are putting out....it should be used for tuning purposes only. go get tuned and get back on the same dyno and see what your gains are
The old motor was running high 13's at 101.X in August last year and that was without the NWP spacers on it.. I never had any dyno #s on that setup to compare this to. I guess I will just need to bring this one to the track and see what she runs.. The old motor is going into another members 4th gen -- The dyno results yesterday made me wish I kept it instead lol.
ok well te temp on the dyno is not helping, but the dyno op should be able to account for that some.
12.6-12.8 is too fat for na. typically shoot for 13.5 for a simple bolt-on n/a car, but this is not gonna give you the power you are searching for. Soomething seems off though, b/c i made 214/233 bone stock in mine. However, i agree with others hit the track and find out how it runs..
Stock cat is gone, and I have a spare MAF I can try.. it doesnt run like the maf is bad it feels smooth...the o2 sensors are originals with over 120k however judging by the a/f ratio they seem to be functioning fine. For some reason I think the timing must be low but don't know how to measure. My friend w/ a Titan has that uprev/osiris ecu he said he may be able to plug into my car and pull some readings for me.
I'm going to try to play w/ the GTimer I have today to get some #'s with that till I can get to a real track. The heat is pretty high though so I'm sure that will play a factor as well..
So, I took her to the track today -- 1/4 mile dallasraceway.com in crandall, tx. Weather was 97F and 29.35 barometric pressure per wunderground.com -- DA calculated to over 3700ft.
Even w/ the weather I was immediately disappointed w/ my first 2 runs:
both were 14.6 @ 94mph -- WEAK, guess the Dyno didn't lie.. sorry I left the timeslips in the car but can scan them in tomorrow.
I then reset the ECU w/ the ignition/gas pedal trick and ran a 14.5 @ 95mph
After that I let the car cool off a bit and pulled the plate off the exhaust cutout which dumps right after the headers.
From there I immediately ran 14.2's at 97mph. After a few more runs I began to realize the power feels like it drops alot after 6K RPM so I started shifting at 6K instead of taking it to fuel-cut.. I eventually hit a few 14.1's and trapspeeds were in the 98mphs.
Still very disappointing to me considering the old motor was hitting 13.9s @ 101.X last summer without the cutout or nwp spacers... I think the DA was worse today though for what that's worth.
A guy with a Jeep SRT8 was impressed w/ my car?? and came over to talk to me about it for awhile. He was doing 13.5's and 100-101mph -- he told me his traps and ETs were off by a few tenths and a couple mph today (again for what thats worth) He even asked me to run.. I'll post that timeslip tomorrow too, but he crossed the line by about 3-4 carlengths ahead of me and said I surprised him w/ the amount I gained after opening the cut out.
There was also a guy he was talking to with a 6spd GTO with intake/exhaust running mid 13's and 100-101mph also. (not sure what they normally run/trap)
So, initially I felt horrible about the times but worked my way down from 14.6's to 14.1's and gained traps from 94 to 98mph along the way. I think something is holding my timing back causing the power loss. I am going to relocate the knock sensor/ground it (which I did on my old motor, but currently have in stock place on the new motor)
Any feed back guys? Like I said, I'll post the timeslips tomorrow.
Honestly, that doesn't sound too bad considering the DA for your runs..The DA on my passes were ~2200 and I made basically the same power you did and only trapped 99.77 so..
You need to get tuned, I bet that makes a WORLD of difference..
Thx man, I'm still going to redyno at a different shop thats running a $35 special in a few weeks just to see.. I know the weather isn't doing any favors, but still feel my #s (both dyno and track) should be better compared to my #'s last year w/ less mods. . .
You are correct sir. But that doesn't go for every car because we all know every car is diffrent. My car is tuned around 13.1-13.3 on motor and then it drops to 12.8's & 9's above 5k rpms..
Hmm..just odd. I know every car is different, but an n/a v6 vs. n/a v6 being almost a point apart to make power seems odd, but I wouldn't really know on the VQ..now I do. My car is tuned 13.3-13.6 tapering to 13.1-13.0 above 6000rpm.
Considering the conditions not bad times at all. I wouldn't think you car is really down on power if it wasn't from the times of your previous engine. But were those times in similar conditions?
thats great! nothing wrong with that tune..
I'm pretty sure you can call them up and have them send you the runfiles. Try that and post them. VIAS doesn't seem to be functioning properly. Get your friend to get some data via his Cipher. Most namely timing & maybe some MAF flow #'s with respect to RPM.
old motor with cai,headers, udp was 13.9 @ 101 -- roughly 2200ft DA that day.
new motor w/ cai, headers, udp, nwp spacers, and block off plate was 14.6 @ 94 then 14.1 @ 98 with exhaust dumped after header. -- roughly 3800ft DA.
I'm going to try to bug my friend to get some cipher logs for me this week and will post those as well as runfiles if I can get that shop to email them to me..
Not sure i'm a fan of the block off plate, I may try to put the VIAS back..
Yes, so far still plan on running Friday. I need to relocate/ground my knock sensor like I had it setup on old motor I feel this may be the key to getting the #'s back on track.
No, on the dyno the IM was in stock form w/ VIAS hooked up; the only mod to IM was the NWP spacers. . I removed the VIAS valve and installed the block-off plate after I got home from the dyno and ran it the following day at the track w/ plate installed..
Do you plan on relocating it to where it would still be functional? I plan on doing this but am not sure on optimal points so that it'll still function properly.
Not particularly. The way I had it before was KS wrapped in a rag and ziptied under a coolant line above and to the left of the shift linkages.. I connected a wire to the bolt that runs through the hole in the KS and a washer & nut on the other end to hold the wire on. Then ran the wire to the chassis for ground. Who knows if it even had a positive effect or not but I'm going to redo it this way tomorrow and see if I feel any difference... I'm going to the track again this Friday & will run it this way.
That dyno shows a vehicle w/o a functioning VIAS.
I had the same feeling, that's why I took the VIAS valve out and put the block-off plate on before going to the track on Sunday. However... my track#s were pitiful.
old motor last August: CAI/Headers/Pulley/Grounded_KS/Stock Exhaust - 13.9s @ 101
new motor this June: CAI/Headers/Pulley/NWPs/BlockoffPlate/Stock Exhaust - 14.6s @ 94
then Open the cutout - 14.1s @ 98
I went back and checked, the DA between the 13.9s last year and the 14.6's this year was about a 1000ft difference. I dont think a 1000ft DA difference is going to drop traps from 101 to 94mph on a car that has more mods??? Keep in mind when I ran 14.1s @ 98 on Sunday thats with the exhaust dumped after the headers which I did not have last year on the 13s runs.
So, I relocated the KS --> bolted/grounded it to the chassis instead where the old battery tray used to be (batt is now in trunk.)
I took her for a spin and here are my findings (take note this is with the cutout closed, and exhaust flowing out through the stock catback system)
Roll into 1st gear.. about 3K+ its breaking the tires loose/chirping/spinning.. at redline I grab 2nd quickly and it is now trying to DESTROY the tires, spinning so bad!
The car has not done this since I can last remember. The only thing I changed on the car was the grounding of the KS, so unless there is some freak high pressure front blowing in or something else, this has to be the difference maker. **I checked wunderground.com and it is currently 91.7F and 29.8 Barometric Pressure so that obviously isnt doing the car any favors.
The sound of the intake has also changed and I also now hear a new sound I havn't before -- it is almost like the sound of the air rushing through the intake & manifold when throttle is full @ upper RPMS.
I was so happy I almost drove straight over to the same dyno place to see whatup lol. Not sure I want to eat another $63 to redyno it right now b/c I'm going to the track tomorrow. I may just let the timeslips do the talking to see if the #'s backup the difference i'm feeling or if its all in my head..
Yeah I got one on my cell phone ill email it in and attach it somewhere. My dyno charts on the first post arent showing up anymore for some reason? yet they show up on the maxima.org album when I check? Maybe I need to relink them, gimme a min i'll post a pic of the KS
EDIT: Here it is, bolted to the bracket in front of driver side motor mount -- the battery tray is usually on this location:
Have a safe trip on the way down to "Big_D"
lol
