Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Aackshun's Dyno Thread
Old 03-28-2010, 08:38 PM
aackshun's Avatar
Hey guys, just got back from Houston-Nissan's Dyno day, wanted to post my baseline before I add VQ35DE cams and any other mods that come my Maxima's way. I'll make an official post in the moderated thread when I scan the dyno sheet (scanner is being stupid now).
On to the biz...
(Sorry for the crappy photo, I guess it's better than nothing for now)
Dynojet- 4th Gear - 173whp (@ around 5.6k) / 185 wtq (@ around 4.8k)
Tried to get a AFR but my car sprayed the sensors and killed the readings
1999 SE-L 5 Speed, 170,xxx miles.
Current Modifications:
Bomz SRI
Warpspeed Y-Pipe
?Brand? High Flow Cat
RT Underdrive Pulley
G35 Coupe Rims on Michellin Sport PS2s (235/45/17)
Amsoil 10w30
93 Octane
'02-03 Maxima VQ35DE cams soon.
[edit]Then a minor exhaust mod.
Even further down the line in my dreams... An actual VQ35DE lol.
QUESTION!
What is that silly nilly dip @ 3-3.5k? I see it on other maximas with the same mods, fewer mods the dip becomes less pronounced but on maximas w/o a cat (or high flow cat) the low end seems to be lacking and that dip becomes a bit more extreme.
aackshun is offline
Old 03-29-2010, 02:54 PM
ajcool2's Avatar
Any reason why you would put a stock 5.5 gen exhaust on the car?
ajcool2 is offline
Old 03-29-2010, 03:08 PM
Crusher103's Avatar
+1 just go aftermarket. buy an Apexi or Cattman rear section if u are worried about noise.
Crusher103 is offline
Old 03-29-2010, 03:39 PM
aackshun's Avatar
I hate that stupid bend from the cat to the B-pipe currently on the car, even if I don't get any gains my mind will be at ease. I also have flat spots where the bends are, for OEM this is either a cheap replacement or Nissan really dropped the ball in '99.
Also I can get one for $50.
aackshun is offline
Old 03-29-2010, 07:42 PM
Silver Tooth S2K 9k FTMFW
95 maxima se's Avatar
nice run, did you change the cat to a magnaflow?
95 maxima se is offline
Old 03-29-2010, 08:28 PM
aackshun's Avatar
I thought the cat was?? I thought you picked up the warpspeed+magnaflow cat deal when you had the car, cause the cat is spot welded to the Y-Pipe, so I assumed it was part of that group deal...
Please don't tell me it's stock... Cause it throws an emissions code lol.
aackshun is offline
Old 03-30-2010, 12:23 PM
Redline Maxima's Avatar
these are similar numbers to what i dynoed. my difference in mods were headers, no pulley, stock cat and i did 179whp and 183wtq. engine was heat soaked and it was like 95 degrees that day, even though i dynoed after 6pm, lol. i will dyno again soon with my new mods.
Redline Maxima is offline
Old 03-30-2010, 01:56 PM
Turbo'd Saab
DrunkieTheBear's Avatar
Why not do an 00vi
DrunkieTheBear is offline
Old 03-30-2010, 02:23 PM
Crusher103's Avatar
every gen is that flat spot in the exhuast, just go aftermarket to get rid of it.
Old 03-30-2010, 03:41 PM
99BlackMaxMS's Avatar
Why not do an 00vi
Exactly my thoughts...
I dynoed 200whp and 194wtq with the mods in my sig
99BlackMaxMS is offline
Old 03-30-2010, 06:26 PM
aackshun's Avatar
Why not do an 00vi
I'm going VQ35DE, I'd rather not go out of my way that much, unless I'm horribly misinformed, 00VI setups are $250 and up, and this ~$80 detour is change compared to that.
Hrmm, I took another look, you're right, I'll just get a shop to fix me up a straight pipe w/ an 02 bung from cat-> b-pipe. Because just having that thing there below me bothers me... Allot, atleast I can add mental HPs lol.
The only aftermarket exhaust I'm considering is a full 3" catback, but I don't have the motor that needs it yet....
I'm just doing little cheap things that may or may not have an effect.
aackshun is offline
Old 03-30-2010, 06:42 PM
Boosted Panda
Flava_24/7's Avatar
If its bad, just have it replaced. You could buy a used OEM cat or new OEM replacement and have the exhaust shop weld up some flanges for the Y pipe. No sense in getting a hi flow cat since they dont give any real gains unless you find one really cheap.
Flava_24/7 is offline
Old 03-30-2010, 06:52 PM
aackshun's Avatar
If it's bad then I'll hop on that ebay $30 test pipe unless I find something cheaper. All depends on if Jr put on a aftermarket cat or not...
Also can anyone explain that silly gaga curve @ 3-3.5k??? Or is it something that N/A VQ30 owners have to accept... I see it on a couple of dynographs but not all of them...
aackshun is offline
Old 03-30-2010, 07:02 PM
Crusher103's Avatar
it would probably be easier to just go on ebay and buy a megan unit, it shouldnt be over $30 shipped, they are all resonated on there so it wont be as loud as people like myself running unresonated. with a good resonator in ur B-pipe and a good rear section u should have issues with noise.
Old 03-30-2010, 07:09 PM
aackshun's Avatar
I'm not talking about cat in that post.... I'm talking about the...
Cat -> Pipe w/ 02 bung -> B-Pipe
I find it pretty stupid, that almost S shape curve is what bothers me, who knows if it'll make a difference or not, at least I"ll be happy....
aackshun is offline
Old 04-07-2011, 10:01 AM
aackshun's Avatar
Just adding this to make this my master dyno thread.
http://forums.maxima.org/7854364-post86.html
Dec' 2010 190whp/210ft/lbs
aackshun is offline
Old 04-07-2011, 06:16 PM
Grand_hustle17's Avatar
Seems a lil low, am I tripping?? My auto with, ebay intake, ebay shorty headers, 2.5" catback and a pulley dynoed 182whp and I wanna say 189tq......... auto!
Grand_hustle17 is offline
Old 04-07-2011, 07:51 PM
aackshun's Avatar
Uhhh, you have .5 more liters than me, you also realize that the dyno in the OP is from when I only had a I/Y/HFC right?
I'm just adding my previous post to this thread because this will be the one thread I'll update in the future.
aackshun is offline
Old 04-08-2011, 03:06 PM
i dynoed 238whp auto with just I/H/E
182whp was my 4th gen auto.... i owned 2 4th gen auto's and a 5th gen auto before my 3.5
Old 04-08-2011, 03:28 PM
dot dot dot ...
NmexMAX's Avatar
Hustle should get his runfiles.
NmexMAX is offline
Old 04-08-2011, 05:37 PM
aackshun's Avatar
On a Dynojet/Stang dyno? Not a dyno dynamics or anyt other one?
Either way, still good #'s for an auto.
aackshun is offline
aw11power
10-10-2021 04:57 AM
04-16-2020 05:15 AM
mkaresh
03-12-2018 06:48 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: Aackshun's Dyno Thread
