Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
247/243 03 4AT
Old Apr 22, 2011 | 05:47 PM
NmexMAX's Avatar
dot dot dot ...
Actually, 246.64 w/ a smoothing factor of 5
Did some runs after a 4 year hiatus. (5-4-07 was my last session)
The differences are the intake, spacers and Cattman 3", and fast cat.
My last dyno was LRMAF (fully screened, 82mm( strapped directly to the cone filter, ub3r short and no velocity stack and a test pipe with Cattman b equipped with the moroso spiral flow race muffler, cherry bomb 18" resonator and stock muffler.
This new intake incorporates the stock Helmholtz, custom 3" ID MAF housing (no screen and 76.2mm vs 82mm ID) and JWT POP (3"ID).
And the spacers, except I do not have the elbow to manifold spacer installed because of my SSIM, haven't had the time to shave the center section.
I think that's it.
In my experience, I've seen that the stock Helmholtz + POP gives the smoothest power delivery curve. Tomorrow will prove or disprove this theory. (no 5200RPM hump).
I also seriously feel like it has more pull with the new PUR engine bushings. Tires lose traction even easier than before the bushings at about 6000-7000RPM.
Threw on my lightweight 17's this afternoon to keep things similar and remove any variability, by the way, compared to the Z33 tracks, it looks like shyt now.
Long story short, ran out of time, only got 2 runs in, she's got more in her with some finer MAF conditioning.
Good news is that I gained an average of 10 ft/lbs from 3700 - 4400 and 3-5 whp from 4700-5500 and 5-8hp from 6000-7000. Peak #'s weren't very different than last time.
246.64@ 5911 RPM / 242.82 @ 4336 RPM. Taking out 12-14% fuel early on from 4000-5500 then gradually down to about -7% from 5500 to 7100.
AFR was 13.5 or so then down to 13.2 towards 6000 - 7100. It likes being leaner. Gained about 3 peak whp on the second run from removing fuel globally about -2-3%. I think going -5% all around (total, so 2-3 more % from this run) would put me at around 250.
It sounded amazing too
I want to go a bit leaner next time
Average hp difference from 6-7k (+):
6000 5.97
6050 5.14
6100 5.6
6150 5.51
6200 5.95
6250 7.23
6300 6.79
6350 8.26
6400 6.91
6450 8.8
6500 6.47
6550 5.32
6600 4.32
6650 6.97
6700 5.62
6750 6.01
6800 5.82
6850 8.04
6900 9.79
6950 6.47
7000 9.86
AVG: 6.7
torque:
3750 9.4
3800 9.85
3850 10.35
3900 9
3950 8.29
4000 8.27
4050 9.29
4100 10.2
4150 11.82
4200 10.09
4250 7.56
4300 6.99
4350 5.5
AVG: 8.97
Averages across the board were about +4.8
Comparison to my last best regarding the differences between them re: info above:
Both hp & tq
HP only:
Torque only:
Today's runs:
AFR (hi res, check the scale)
Old Apr 23, 2011 | 08:13 PM
NmexMAX's Avatar
dot dot dot ...
It was spur of the moment thing so I didn't take my logging software ....
Old Apr 23, 2011 | 08:42 PM
MoncefA33's Avatar
Strong numbers. Go to direct IGN/INJ control.
Old Apr 23, 2011 | 09:37 PM
ajcool2's Avatar
Nice. Get the a/f around 12.8 and you'll definatly gain more hp.
Old Apr 23, 2011 | 09:45 PM
NmexMAX's Avatar
dot dot dot ...
Seems to like the "leaness" though. I'll post a comp vs my old best vs my new best. Old best was around 12.8 or so.
Red is the latest:
Old Apr 23, 2011 | 09:53 PM
azdevils013's Avatar
Good numbers man. I can't wait til I get to a dyno. Can you send me the run files?
Old Apr 24, 2011 | 12:12 AM
Originally Posted by NmexMAX
Analyze it ****! You're into engineering crazy man ...
That's the plan. I've got summer coming up, so I will have some free time on my hands. It sucks I have to switch from mac os to windows every time I want to tune or check run files. I'll also be able to get back with Vivid Racing again and talk my car over with some techs.
Old Apr 24, 2011 | 12:27 AM
aic96max's Avatar
def think youd make better #s with a richer tune, my 4.5 and my buddies 5.5 both liked the 12.8s-12.9s ober 13s , while on the dyno
Old Apr 24, 2011 | 12:32 AM
NmexMAX's Avatar
dot dot dot ...
I go rich and the **** goes down in powah. Doesn't anyone remember Matt's theory?
Old Apr 24, 2011 | 01:36 AM
aic96max's Avatar
i guess timing can come into play, maybe me and my boy had some slight knock which was mitigated by the richer mix
Old Apr 24, 2011 | 06:13 PM
Grand_hustle17's Avatar
these were the numbers i would expect if i still had my auto, ill be dynoing soon too but congrats
Old May 6, 2011 | 12:48 PM
NmexMAX's Avatar
dot dot dot ...
I thought I'd post this for informational purposes.
This essentially shows what a larger MAF, 3" exhaust, and an SSIM do.
This is skidz vs my dyno, man I wish he wouldn't have sold it
Old May 17, 2011 | 01:53 PM
Payu's Avatar
Any track runs on this car??
Old May 18, 2011 | 06:34 AM
NmexMAX's Avatar
dot dot dot ...
Not as of yet. The track is further than the dyno. Although during the summer they do have those import or legal street things that are cheap and are at night (keep DA's down).
I plan on dynoing again this Saturday, changing up fuel and using a test pipe and different intake.
Old May 18, 2011 | 08:18 AM
Stormzusmc's Avatar
should put a full list of mods =P
Old May 18, 2011 | 11:41 AM
NmexMAX's Avatar
dot dot dot ...
True ..
Nothing special though.
From the top:
JWT POP/3" ID MAF/Stock Helmholtz
NWP spacers (minus the elbow to plenum)
SSIM
Cattman Gen I Headers
Cattman Fast Cat
Cattman 3" Catback
TS F-Spec
SAFCII
Old May 18, 2011 | 01:11 PM
Payu's Avatar
^^ Dont get me wrong I am just looking around on different forums to get an Idea were I am standing at.. I Dynoed about a year ago with numbers pretty close to yours before you added the SSIM and I did an SSIM for myself and added the NWP spacers, LRMAF and 3.5 SRI but didnt get a chance to Dyno I just went to track and saw an improvement of 2mph and -.10 from my PB on the 1/4mile thats why I am asking
Old May 18, 2011 | 01:41 PM
NmexMAX's Avatar
dot dot dot ...
So this is a dynojet that you went to with SAE corrected numbers?
Yeah, I lost power using the SSIM when I hadn't tuned for it (tuning being Z33 CVTC's and a higher rev limit).
Also, were your DA's nearly identical when you ran your comparative track times?
Old May 18, 2011 | 02:10 PM
Payu's Avatar
Yes Dynojet I have the runfiles and the Dynojet software so I can see them on any correction factor..
Yes I street tuned the afrs again after SSIM since they changed a lil bit..
I am going to try to go to Dyno again to see whats up..
Old May 18, 2011 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
That's what I like to hear ... You got PM.
Old May 19, 2011 | 08:03 AM
FlawleZ's Avatar
Good numbers man. Good to see you have realized respectable gains across the rpm range with the changes. I just installed my spacers yesterday except I didn't have time to do the lower plenum spacers but did do the elbow spacer. Your car and numbers are inspiration for me to keep toying with my daily.
Old May 19, 2011 | 09:55 AM
NmexMAX's Avatar
dot dot dot ...
Yeah, these are pretty fun. I need to find me a real weekend toy though.
The spacer that has not been installed as of yet because I currently have an SSIM and I need to remove the center split on the spacer.
At the same time, before I do cams or anything of that nature (cams, advanced piggyback), I plan on doing a very thorough SSIM, really clean the heck out of it as 6_spd_Hayes did ... But I need a spare IM first.
Old May 19, 2011 | 12:00 PM
Payu's Avatar
Did you received the files??
Old May 19, 2011 | 12:30 PM
NmexMAX's Avatar
dot dot dot ...
Sure did. Thanks again.
I noticed you got a little hiccup in a couple of those runs, did you see or otherwise notice it?
During some of my runs I too have a similar dip and I actually witnessed the car sorta buck slightly.
Also, you're in 3rd gear, but when did you go WOT for those runs, and did your lock-up lock? Looks as if it what mind did for my first runs ever, there is a small, what looks like a loop in the hp/tq band and it was indeed my lock-up.
And did in any of the runs did it downshift?
And you will get this a lot from me ... why not rev it to 6550?
Old May 19, 2011 | 12:51 PM
Payu's Avatar
Yes I was having Issues with the settings on my VAFC that was causing a lean spot at that time i fixed them later on and the problem with the revs its that i hit the speed limiter on 3rd gear before 6500 and yes I probably engaged the lock-up I was a novice on Dyno with automatics at that time... And yes I think car downshifted on one of the runs..
Old May 19, 2011 | 02:30 PM
NmexMAX's Avatar
dot dot dot ...
Hehe yeah, check out http://forums.maxima.org/dyno-discus...no-thread.html and you'll see I did the same thing when dynoing this thing.
That's strange that you hit the limiter. Even before my ECU, I never hit the limiter in third and was able to go all out to 6600 or whatever it is.
Also, did you have an independent WB since I don't see any AFR on your DRf's, or at least I hope that's not your AFR, 14.7 all the way ...
Old Jun 2, 2011 | 09:58 AM
Payu's Avatar
I went to the track on Monday and I managed to get 13.96@100mph on regular street tires with some weight reduction spare and jack no rear seats and passenger seat so now I am happy with my SSIM and the 3.5 SRI and LRMAF still on stock ECU and VAFCII I am going to get the 3.5" IM elbow done to see if there its any improvement over my modified stock elbow...
Old Jun 4, 2011 | 09:54 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
checked my fedex, and looks like itll be to you in a couple days. tuesday.
MIKERNM1990
50
Jan 29, 2017 04:28 PM
Unclejunebug
Apr 2, 2016 05:42 AM
MIKERNM1990
1/4 and 1/8 Mile Racing
397
Apr 29, 2013 10:48 AM
sixteenXnine
Dec 18, 2008 03:55 PM
