Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
What is good transmisson fluid for a automatic.
Old Jun 24, 2003 | 08:46 PM
NyCzBuBBa's Avatar
How many quarts will I need????
This is for an automatic transmission 95' SE 75kmiles on it
Also Oil what should I use at 75k miles I use castrol 10w40
Old Jun 26, 2003 | 07:30 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: What is good transmisson fluid for a automatic.
http://forums.maxima.org/showthread....hreadid=129685
Good ATF choices: Mobil 1 ATF, Amsoil ATF, Redline D4 ATF. Mobil 1 can be had at most major auto parts stores.
Cliff Notes for VQ30DE and VQ35DE engines:
Recommended oils:
Dino and "Blend" oils:
Castrol GTX 5W/30
Mobil 1 Drive Clean 5W/30
Mobil 1 Drive Clean Plus 5W/30
Pennzoil PureBase 5W/30
ULX-110 5W/30
Drain Interval: Up to 5k
Synthetic oil:
Amsoil TSG Series 2000 0W/30 Synthetic
Mobil 1 SuperSyn 5W/30
Amsoil ASF 5W/30 Synthetic
Redline 5W/30
Drain interval: Up to 10k with oil filter change halfway through chosen interval (i.e. 8k drain interval -> 4k oil filter change)
For hot climates (i.e. south), 10W/30 can be substituted
Oils to Avoid:
Any Valvoline Oil (consistent sub-par analysis results, all tend to shear down real quickly; additive packages are inferior to other brands)
Any Castrol Oil (consistent so-so to sup-part analyses results and shady marketing practices)
Royal Purple Oil (too expensive considering there are other better synthetic oil choices)
Recommended Oil Filters:
STP S6941 (Some fitment issues on VQ35DE engines)
Bosch 3323
Nissan OEM 15208-9E000 ONLY; for all VQ30DE and VQ35DE engines)
Mobil 1 M1-105 (fits VQ35DE only)
Mobil 1 M1-110 (fits both VQ engines, but bypass valve isn't as good as M1-105 filter)
Amsoil SDF-20
Oil Filters to avoid:
Nissan OEM 15208-65F00 (specified for VQ35DE; refuse to purchase this filter as it has cardboard endcaps like low quality Fram filters)
Any filter made by Fram
Amsoil SDF-13 (pricier than SDF-20 and smaller)
Mobil 1 M1-108 (pricier than M1-110 and smaller)
Old Jun 28, 2003 | 12:31 PM
bigdo26's Avatar
just curious, whats wrong with the fram filters? used them on my old car all the time...
Old Jun 29, 2003 | 03:45 PM
iwannabmw's Avatar
Cardboard end caps for one.
Old Jun 29, 2003 | 09:27 PM
releasedtruth's Avatar
rilla dope
Trust me, if Bill says it's crap, it is. There's no finer "lube" authority.... I'm told. I hear Astro Glide is a fine product though
Old Jun 30, 2003 | 07:57 PM
Jer's Avatar
Jer
What's wrong with Castrol exactly? I recall seeing oil tests coming out in their favour or at the very least they were always above average.
Old Jun 30, 2003 | 08:43 PM
bill99gxe's Avatar
Castrol Syntec and Castrol Syntec Blend oils are not anything special. There are better and more proven oils for Maximas out there for the money.
Only Castrol GTX dino oil is recommended based on good lab analyses.
Old Jun 30, 2003 | 08:56 PM
bill99gxe's Avatar
Castrol GTX dino oil is the only recommended Castrol oil. The Syntec and Syntec Blend oils are relatively poor choices both in value and performance.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rbuswell
Nov 17, 2016 04:54 AM
pkfinn
Jan 3, 2016 02:55 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
