Transmission fluid
Maxima.org Sponsor and Donating Maxima.org Member
The total dry capacity is ~ 10 quarts, but if you follow Nissan's recommended procedure to drain and refill it will take anywhere from 4.5 to 5.5 quarts depending on how long you let it drain, temp, etc. As recommended in another post to this thread, suggest you measure the amount that comes out. Assuming the level is correct before you start, measurement of the old oil will get you in the ballpark quicker and will minimize yoiur chances of overfilling. Ed
Here's a trick I learned the hard way. 1st time I changed the ATF on my Maxima, I captured and measured the old fluid. Then replaced the same amount with fresh fluid. Yet I had to check & add fluid for a week or so to make sure it was full. Never quite sure when it was right. When it came time to changed the fluid on my Altima, I checked the fluid cold and hot for 2 weekends prior to the job. That way I had a benchmark level on the tranny dip stick to compare. Then when I changed that fluid I was able to hit the mark exactly and did not have to add anymore later.
i'm not sure what i should use. i live in new york. it can get very cold and very hot here.
http://intershop.amsoil.com/cgi-bin/...e/Catalog/1112
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
