Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Used New Oil in car. Looks really promising.
Old Oct 14, 2003 | 12:14 PM
LastBoyScout's Avatar
About a month ago, i set the idle RPM's to 1 grand so as to take car of my sometimes laggy starts in 1st gear. That fixed the problem just fine.
Then yesterday, i was changing the oil, and used Quaker State's Peak Performance 10w-30. This morning the car idled at 1,500 RPM. I cranked it back down to 1 grand, and my car seems to run alot better and the engine temp seemed to drop a few degrees.
Thought i should share since most engine oils/addatives i have seen dont do $#!7
Old Oct 14, 2003 | 12:53 PM
BRIGBOY's Avatar
Is that stuff full synthetic or what? Interesting...
Old Oct 14, 2003 | 02:03 PM
Im sure it is....but once you go synthetic, dont switch back to standard.
Old Oct 14, 2003 | 02:58 PM
baracus's Avatar
bad choice for oil
Old Oct 14, 2003 | 03:14 PM
matty's Avatar
Mobil 1 Fully Synthetic...Best oil money can buy
all the newer synthetics allow you to switch back to dyno oil if you want to and go back to syn..why anyone would want to do that is beyond me. go to synthetic and call it a day
-matt
Old Oct 14, 2003 | 04:00 PM
Wisky97SE's Avatar
Whats the reason to this; most every mechanic I talked to said it was okay to switch back after using synthetic.
Old Oct 14, 2003 | 04:32 PM
matty's Avatar
it is ok to swtich back...when synthetic first came out, it was advised not to mix.
-matt
Old Oct 14, 2003 | 05:15 PM
maxNYC's Avatar
Castrol actually has a blend mix that is half oil and half synthetic...
Its ill advised to mix different brands.
Old Oct 14, 2003 | 06:48 PM
njmaxseltd's Avatar
Castrols Synthetic Blend was the worst oil I ever had analysed from my car. Don't use it.
Castrol GTX - Conventional
Mobil 1 & Amsoil - Synthetic
Those are the best 3 oils you can use in your Maxima.
Download Bills spread sheet and see the results for yourself.
Old Oct 15, 2003 | 07:25 AM
Allow me to clarify, you could, but that would be like taking a kids vitamin after having used GMC Mega Man vitamins for over a year. You still get what you need, but now your engine is not getting what it is used to as far as synth addatives.
Old Oct 16, 2003 | 11:49 AM
2002 Maxima SE's Avatar
That makes absolutely no sense what so ever...the car is digesting the additives.
Best laugh I have had today though.
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
