Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Transmission Fluid Flush
Old Oct 20, 2003 | 06:32 PM
Jake96GXE's Avatar
Hey guys this is my first post. I bought a 96' maxima GXE only a little over a week ago and the inspection checked out great. The only suggestion the mechanic had was that i should flush the transmission fluid. Can someone tell me what this constitutes? This is my first car so i'm definitely a car newb. Thanks!
-Jake
Old Oct 20, 2003 | 06:53 PM
fishhouse's Avatar
check out the "Fluids and Lubricants" section of the forum. there is a thread there called "Sticky: How to flush automatic transmission fluid? What ATF to use? How to check the level?". it should answer all your questions.
Old Oct 21, 2003 | 06:08 AM
Albertt's Avatar
-Jake
Welcome aboard Jake. Do as Fishhouse has suggested, you'll find all the info you'll need there. Basically a tranny flush replaces all of the 10 quarts of transmission fluid in the car. THe shop will hook up some lines to your tranny and start a pump which pushes out the old fluid and fills it in with new fluid.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
