Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Bleeding Brake
Old Dec 1, 2003 | 09:52 PM
wcasskicker's Avatar
Bleeding Brake
I've prepared to do my brake bleed, what should I look out?
I've got 4 bleeder screws, 1 bleeder wrench, 1 empty spring water bottle(1000 mL),1 transparent bleeder tubing and 2 bottles of DOT4 brake fluid.
Before I get into the bleeding process, what should I look out? All help are appreciated.
Old Dec 2, 2003 | 02:38 AM
joaquink's Avatar
¿Hablas Español?
If you have ABS, my 97 FSM lists disconnecting the electrical connections for the ABS actuators or the negative battery cable before bleedin the system.
Also, check the specifics on order for your year. I think mine was L rear, R front, R rear, L Front. Sorry - too lazy to get up and check right now.
Old Dec 2, 2003 | 05:28 PM
Finished bleeding, now the brake fluid is clear. Thanx for the help.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
