Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
engine cleaner?
Old Dec 2, 2003 | 10:04 PM
fishpony's Avatar
engine cleaner?
ok i saw this stuff at wal-mart for like 3.50. its a one quart bottle and you add it to your oil before you change it and let your engine idle for 5 minutes and it's supposed to clean out your engine then you drain it with your oil and change your oil. has anyone ever used this or does anyone have any comments?
Old Dec 3, 2003 | 07:02 AM
Mizeree_X's Avatar
Getting back to his roots
Amsoil makes a similar product, I used that when I bought my car at 76k. Changed oil filters, added the engine flush, and ran the car for 10 minutes. It got rid of all the varnish I could see on the heads when I took the oil cap off, so I'd say it works. Never used the 'generic' brands before though.
Old Dec 3, 2003 | 08:18 AM
johnny2kgle's Avatar
Gunk or the equivalent is a kerosene based solvent that will destroy/weaken your gaskets and seals causing leaks. It is crap.
Amsoil flush is the only solvent based (concentrated detergents similar to those in the Amsoil product line) to consider for cleaner the crankcase, but auto-rx is much better.
Here is the link. http://www.auto-rx.com
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
