Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
brand of coolant?
Old Dec 2, 2003 | 09:06 AM
outsider's Avatar
brand of coolant?
what brand of coolant/antifreeze do everyone use?
should i just spend the extra money and get nissan coolant or ill be fine with peak or prestone?
Old Dec 2, 2003 | 11:37 AM
UncleMax98's Avatar
For peace of mind, use the Nissan coolant. I am using Prestone orange coolant (Dexcool) but is regretting my choice. So far no problem after 50K miles, but every once in a while I read horror stories about Dexcool. I am reluctant to switch back to Nissan because to switch between Nissan coolant and Dexcool you need to flush the system really well (I am somewhat lazy and the engine drain bolt is impossible to remove).
Old Dec 2, 2003 | 12:04 PM
spirilis's Avatar
I flushed my cooling system with Prestone antifreeze... no problems so far.
Old Dec 2, 2003 | 10:02 PM
totttalled's Avatar
I splurged for the $15 a gallon Nissan coolant. Apparently this was discussed on another thread where it has a silicate free formulation that is lacking in the Prestone and similar stuff.
I did add Redline's water wetter, BTW.
Old Dec 3, 2003 | 11:04 AM
SkoorbMax's Avatar
Hmm, I am using the $5/ gallon prestone stuff with distilled water. I wonder if my next replacing I should do nissan. I am following motorvate.ca's advice and not flushing each time. The engine drain bolts are all but impossible to get at, so I'll simply dump out the radiator every 15k miles and run my garden hose through the top of it.
Miket2006
Mar 1, 2021 03:55 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
