Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
? about radiator flush
Old Feb 22, 2004 | 06:44 PM
mm347's Avatar
Hey everybody,
My '97 Max has 78k miles and I not sure if radiator flush was ever performed so I wen to a local Nissan dealer (Peruzzi Nissan) to find out how they do it and how much they charge. Well, it appears that they use a machine (not sure which one, but can find out if it matters) for this procedure which uses chemicals to eliminate any debris and accumilations and Prestone antifreeze. Price for the whole thing is $65.99. I also asked about the Nissan antifreeze and they said that it's $20 per gallon .
Does anyone have experience or opinions with such machines? Do they perform a sufficient job of flushing out the radiator and the block or am I better off doing it manually?
Old Feb 23, 2004 | 07:11 AM
twiggy144's Avatar
Radiator flush is one of the easiest task for a DIY'er. I dont believe the power flush has any more value. Sounds like a marketing gimmick. Buy a gallon for 9$ anywhere else but the dealer, and invest one hour to do it yourself.
You read instructions on motorvate.ca
Old Feb 23, 2004 | 07:28 AM
2002 Maxima SE's Avatar
Where else can you get the Nissan silicate free radiator fluid?
Old Feb 23, 2004 | 08:35 AM
mm347's Avatar
I know that it's not difficult to do but since I don't have a garage it would be kind of uncomfortable doing this on a parking lot.
Buy a gallon for 9$
Maybe in Canada prices are cheaper for Nissan's antifreeze but here in Philly area I haven't seen anything cheaper than $16 per gallon.
That's not the answer I was looking for. I wanted to know if the machine can do better, same, or worse job of performing a proper antifreeze flush?
Thanks anyway.
Old Feb 23, 2004 | 09:17 AM
Mizeree_X's Avatar
Getting back to his roots
Thanks anyway.
If the power flush is what I think it is, then it clears out all the old antifreeze in all the radiator hoses, and more importantly, out of the heater core. If you have been faithfully changing your antifreeze, then it probably isn't necessary, but if you don't know when the last time the antifreeze has been changed, then it might be worthwhile. You can also buy a kit for $10 at an auto parts store, where you install a Tee junction at the hose going into the heater core, and flush the whole system that way. Only problem is that you then have to replace the hose you cut in half, and you have to dispose of ~3X more fluid.
Old Feb 24, 2004 | 08:56 AM
mm347's Avatar
I'm not really sure if it is (but it sounds like it), since the tecnician who I spoke with said that they use the machine to perform all antifreeze flushes and it uses chemicals to clear out the system.
I'm not the original owner, bought the car about 5 months ago, so I'm not sure when it was changed.
So, I think I'm going to try it and just buy some Nissan or Toyota red antifreeze instead of Prestone that they use.
Thanks everybody.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
