Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
is that true about Amsoil?
Old Mar 14, 2004 | 06:38 AM
Frank Fontaine's Avatar
I was on another forum and they said it is not API SL category. Isn't that a requirement for warranties? Even the $0.79 oil is API SL.
I'm not a fan of synth unless the car came with it, in which case I would stick with it. But I was surprised at the Amsoil bashing because I thought it was highly recommended here.
Old Mar 14, 2004 | 06:44 AM
outsider's Avatar
look ont he back of the amsoil bottle it should tell you which requirement it fullfil
Old Mar 14, 2004 | 11:24 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
who says this???
i juss went through all my Amsoil dealer catalogs and AMsoil bottles, everything has marking API SL and others.
Old Mar 14, 2004 | 02:56 PM
Anachronism's Avatar
Will AMSOIL Motor Oils void the warranty of a new vehicle?
Absolutely not! Manufacturers’ warranties are based upon the use of oils meeting specific API Service Classifications, for example, SJ/CF. (AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty.)
http://www.amsoil.com/frequent.htm
Old Mar 14, 2004 | 03:46 PM
iwannabmw's Avatar
This has been beaten to death a bunch. Amsoil's motor oils surpass the requirements for the API specs, but the company doesn't pay the licensing fees for all their oils. There's more to it than that, but in a nutshell that's it. The topic has been delved into in depth both on the org and numerous other forums if you're looking for more detailed info.
Old Mar 14, 2004 | 07:53 PM
spirilis's Avatar
As I understand it, the issue is Amsoil's use of extra phosphorous compounds--these can be poisonous to the catalytic converter (if you burn a lot of oil), so other oils use less of them. This compound is one of Amsoil's "secrets" for anti-wear, however it won't pass API certification, so Amsoil didn't even bother going for the certification. That's the gist of the controversy. Alongside this controversy is the way Amsoil has marketed its oil, but I'm not well educated on that side of the argument.
So if you're honestly worried about this, don't use Amsoil if you burn any significant amount of oil, lest your catalytic converter be fouled. Even then who knows how likely it is to actually CAUSE cat failure. But if your engine's in good condition and you want to put some good stuff in there, by all means buy Amsoil.
Old Mar 15, 2004 | 05:01 AM
Ammi's Avatar
350 Detroit Muscle
Whoever said that, give him a because he's wrong.
Old Mar 15, 2004 | 06:49 AM
iwannabmw's Avatar
Yep, one of the big issues is P. What's interesting is that when you use a high quality synthetic that has a lower volatility, your oil consumption thru the combustion chamber is usually reduced. The API specs are a minimum standard that oils should meet. They do not take into account any of the differences between dino oil and synthetics. Just because an oil passes API SL doesn't mean it's a great oil. Granted API SL oils are much better than the oil's a few years ago, but when you look at all the other tests that oil can be subjected to, you will begin to see the differences between .79 cent oils, 1.79 oils and then the synthetics. It all depends what you're looking for in an oil and how you plan to use it.
One interesting thing to note is that P levels are not regulated in the 40 wt. classes. Since 10W-40 and higher viscosities are the typical weights used on older oil burning motors, I would be interested in hearing how many people have catalytic converter failures attributed to to P poisoning.
Another interesting point is that Amsoil's 10W-30 can survive the brutal Sequence IIIF test without any issues. In fact, their 10W-30 has gone 3 times longer than the test normally is and can still pass it with flying colors. For more information on how brutal this test is and the actual results, you can visit here: http://www.mdvsynthetics.com/actionn...quenceiiif.htm
Old Mar 15, 2004 | 07:12 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Jeff92se best explains this (Grab a cup of coffee):
http://forums.maxima.org/showthread.php?t=101531
Old Mar 15, 2004 | 12:24 PM
gerhard's Avatar
Different AMSOIL lubes meet different requirements.
I seem to recall that one of the AMSOIL common motor oils did not meet the SL requirements, but did meet the SJ ones.
Gerhard
Old Mar 15, 2004 | 01:12 PM
spirilis's Avatar
What kind of prices are we talking about for Amsoil's motor oil (5W-30) and gear oil (75W-90)?
Is the "X2000" series Amsoil's "best"? How much is it per quart?
Old Mar 15, 2004 | 01:58 PM
~$60 a case of 12 w/shipping from talkinghorse on this board for the motor oil. I am not sure on the gear oil but I am sure talkinghorse can ive you a price.
http://forums.maxima.org/showthread.php?t=285321
Old Mar 20, 2004 | 08:07 PM
totttalled's Avatar
My bottle of Amsoil 5W30 (ASL) has a circle on the front reading "API Service SL-CF" and on the back on the back it reads "API Service SL, SJ, CF." It's also ILSAC GF-3, ACEA A3, and MB 229.3, making it specwise, one of the most gee-whiz oils out there.
In my experience sometimes the websites take a looong time to update, and can be very different that what's actually printed on the bottle.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Sep 27, 2015 08:37 AM
pjgreek
Sep 9, 2015 09:30 PM
