Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Mobil1 0-40W in
Old Apr 21, 2004 | 03:59 PM
BluFlame's Avatar
Mobil1 0-40W in
I changed oil and put in 0-40, so far pretty good. I was using 5-30w before and always mobil1. 150k miles.
Old Apr 21, 2004 | 05:55 PM
Zigg's Avatar
You're using EuroSpec Mobil 1? It should give you a little more power, but it will probably give you a wee bit less protection. I was looking at it today. Honestly, what Nissan recommends is probably what you should use, unless you have heavy modifications. Also, it's spring time, and you're in NJ... there really is no need for you to use something graded so much for the winter. I typically use 5-40 in the summer.
Let me know how it goes though. With such a large multigrading gap, it makes me really curious.
Old Apr 23, 2004 | 04:52 PM
BluFlame's Avatar
ya, euro-spec. I bought it for winter but didnt use it until now. It pours faster than 5/30. I think it would be a great winter oil for NE peeps. Engine runs smooth and quiet, you should not use this if you are switching to syn for the first time.
Old Apr 23, 2004 | 06:00 PM
Virus's Avatar
Good luck. I hope your oil pump can handle a 40w oil. I know most new cars would croak on it.
Old Apr 30, 2004 | 09:56 AM
johnny2kgle's Avatar
He should be okay. Mobil 1 always runs on the thin side of their viscosities. M1 0w-40 is not much thicker than Amsoil 0w/5w/10w-30 or the Castrol Syntec 0w-30 made in Germany.
That being said, the M1 0w-40 is not as shear stable as the above referenced synthetic oils. The Mobil 1 10w-30 is very shear stable as well.
Old May 18, 2004 | 08:30 AM
00Max00's Avatar
0w is way to thin
ghostrider17
Dec 12, 2006 01:21 PM
messerchmidt
Jul 23, 2005 02:28 AM
Rickalodeon
Nov 8, 2002 05:01 AM
