Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Where is filler on '04 5 speed auto SE?
Old May 31, 2004 | 07:15 AM
Phildo's Avatar
I accidently drained my auto trans fluid instead of oil. I can't seem to find the filler for trans fluid. There is a small black with some kind of lock with a "Use only Nissan atf" on it. If this is the filler, how do I get the cap off. My manual suggests that only Nissan service should replace the fluid on the 5 speed auto, but not the 4 speed. Also, how bad would it be to drive about 1 mile with the transmission fluid down a couple of quarts.
Thanks,
Phil
Las Vegas
'04 Maxima SE
Also, where's the friggin' oil drain plug?
Old May 31, 2004 | 07:25 AM
VQ35DE's Avatar
The Nissan Matic-K ATF goes in that tube you talked about. Take a sharp pointed object and push in on the center of the latch on the front of the black handle. Don't drive that car, use another car to go to the nissan dealer and get some Nissan Matic-K ATF and put it in YOURSELF. The oil drain plug faces the REAR of the car.
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
BobTX10
Oct 7, 2015 08:43 AM
