Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
anyone use mobil-1 75w/90 gear oil?
Old Jun 19, 2004 | 02:09 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
good stuff--bad stuff??
Old Jun 19, 2004 | 04:44 PM
ferran586's Avatar
If you read the stickies in this section you would find that it is actually one of the gear oils recommended for our cars. And for the record I just bought 5 qts of it to change my fluid.
Old Jun 19, 2004 | 05:27 PM
swiora's Avatar
The recommended Mobil 1 is GL-5, bust several posts state that only GL-4 should be used (per the manual). Who can shed light on this paradox?
Old Jun 20, 2004 | 01:23 PM
jtacy's Avatar
I read, perhaps on bobistheoilguy.com, that synthetic GL-5 (such as Mobil 1) is fine. It is the non-synthetic GL-5 oils that require sulfur additives (which are said to chew up certain types of synchros) to meet spec. I don't know for sure, but it is plausible and seems like a good place to start researching.
Old Jun 20, 2004 | 02:38 PM
ferran586's Avatar
If you go here you will find a line about half way down the page that states "Mobil 1 Synthetic Gear Lubricant LS 75W-90 can also be used in rear axles where API Service GL-4 lubricant is recommended"
Old Jun 20, 2004 | 05:36 PM
jtacy's Avatar
Some manufacturers will actually specify GL-5 oil for the rear axle and GL-4 oil for the gearbox. The problem with GL-5 in gearboxes is that it is thought to contain additives such as sulfur that can be corrosive to copper alloys such as those used in synchronizers. Rear axles don't have any such vulnerable metals. Now, some people have claimed that manufacturers put anti-corrosive additives in GL-4/GL-5 compatible oil to prevent damage. Tough call.
Old Jun 21, 2004 | 03:45 PM
ferran586's Avatar
Aaah. Ok. Thanks for little info.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
