Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Coolant Flush Question
Old Jul 30, 2004 | 11:27 AM
Chron!cRAGE's Avatar
I have read the stickies and numerous threads about this but I still have a question. Motorvate's site says that the engine holds about 2 litres and the rad holds about 5 litres. So once the system is pure distiled water how will topping off the radiator with 100% coolant give a 50/50 mix of coolant and distilled water?
Or should I just go cheap and drain/fill the radiator with a premix of 50/50 to be on the safe side. Thanks.
Old Jul 30, 2004 | 11:46 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What I do is keep flushing until there is ~100% distilled water.
Then I dump the radiator and add whatever amount of coolant you need, ie if it's 7-liter capacity and you want 50/50...dump in ~3.5-liter of coolant and then top off with water until full. Plus, I throw in a bottle of water wetter.
Old Jul 31, 2004 | 09:01 PM
JamesNH's Avatar
what do you do with the liquid as your flushing? Couple big 5 gal drums? Where do you dispose you coolant?
Old Aug 1, 2004 | 08:10 PM
{-_-}'s Avatar
distilled water... damn, gotta head to the supermarket (can't use water from the garden hose).
Old Aug 22, 2004 | 11:35 AM
00MaxSE's Avatar
Pointy Elbows
What is the capacity of the 00-01 maxes? I'm flushing mine as we speak.
Old Aug 23, 2004 | 07:01 AM
lefty
Probably makes sense that if you have 2 liters in the engine you put in 2 liters of coolant to make a 50/50 and then top up the rest with a 50/50 mix.
I ended up approximating.
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
junito1
Sep 23, 2015 12:14 PM
RWCreative
Sep 21, 2015 11:01 AM
