Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: What type of Oil? (Discussion Welcome)
Synthetic
173
71.19%
Dyno 5w30
41
16.87%
Dyno 10w30
29
11.93%
Voters: 243. You may not vote on this poll
Oil Survey
Old 01-12-2005, 05:31 AM
  #41
Rogo02SE's Avatar
Originally Posted by SSurfer
any syn. when funds are low I go blend
From my own experience I don't recomend switching between synthetics and dino oils back and forth. Stick with one kind if you plan to go fully synthetic try not to go back to dino. I used to do it on my 89 ford festiva No comments and the valves rattled like crazy.
As far as synthetics go I highly recomend them. When I was redoing the top end on my 96 Talon TSi AWD turbo. There was absolutley no buildup on engine's internals.
Different story with My 91 Talon TSi AWD turbo. I was using castrol gtx 10W30 and there was a lot of buildup on engine's internals when I had the head rebuild on it.
Rogo02SE is offline
Old 01-12-2005, 06:01 AM
  #42
RaTgoesMaX's Avatar
I have just found out that Nissan is now recommending Mobil 1 for the Nissan lineup. This is a 180 approach to the thinking process at Nissan.
In the 12 years that I have been buying their product not once was Syn oils recommended. However, I also was not discouraged from using them.
I picked up a phamplet printed by Nissan showing a number of their vehicles and jugs of Mobil 1 and a sticker that says Mobil 1 racing(tacky). Oh Well, times are a changing.
RaTgoesMaX is offline
Old 01-12-2005, 06:11 AM
  #43
guyfromkop's Avatar
quaker state, high performance, 5w30 winter 10w30 summer. cant beat what has been one of the longest running oil in the car oil industry
plus i dont know one mechanic that says it's not a good product
guyfromkop is offline
Old 01-12-2005, 06:25 AM
  #44
passEMonTHErite's Avatar
Mobil 1 10W30 summer. Mobil 1 5W30 in winter. Fram filter.
I've been doing 10,000 mile drain intervals. I've always assumed thats okay. Dont some people make it last 12-15 thousand?
passEMonTHErite is offline
Old 01-13-2005, 12:36 AM
  #45
Go Get a Life!
japmaxSE's Avatar
My2cents
I've only been working around cars for what 5yrs now and of my experience with oils and what each brand can do, bottom line is all petroleum motor oils are all the same it doesn't matter what brand you use, your wasting your time and money going for name brand stuff. If you go regular motor oil then get the cheapest one it doesn't matter it will perform the same way as your so called industry leading brands it's all a gimmick to confuse you. If your smart and know when to change your oil for your vehicle than you should be fine. That goes for Castrol, Mobil, Valvoline etc.etc.
Now for us performance guys we all know synthetic motor oil outperforms all petroleum motor oils hands down.
japmaxSE is offline
Old 05-09-2006, 05:29 PM
  #46
friedbacon's Avatar
Used to use the bulk 5w30 oil from my workplace. I guess my car didn't like it because it sounded louder in the morning (hey it was free oil!). Now I've switched to QS 5w30 and it seems that the car is not as loud. I might try castrol GTX 5w30 next due to the recommendations from fellow ORG memebrs.
friedbacon is offline
Old 05-13-2006, 02:04 PM
  #47
yutnaka's Avatar
German Castrol 0w-30 all the way!!
yutnaka is offline
Old 05-13-2006, 08:40 PM
  #48
Torkaholic's Avatar
Well, I don't care what any mechanic says or does not say about Quaker State. And I don't put much stock in all the millions of Amsoil web sites (though it's generally a fine product). I put my faith in objective results. With that in mind, I'd respectfully challenge any VQ owner to show me a substantially better used oil analysis than the one you'll find at the link below. This is my last UOA on German Castrol, taken with just under 5k miles on the oil, which is still in service, and will remain so until 7500, the wty-safe max. Any takers??? I've posted this here before; if you haven't seen it, check it out: http://theoildrop.server101.com/ubb/...c;f=3;t=003426
Torkaholic is offline
Old 05-14-2006, 06:57 AM
  #49
Bobo's Avatar
I switched from dino oil to synthetic oil for the first time 3 months ago. I used Castrol GTX 5w30 for the most part, but am now using Esso XD3 Extra 0w30, PAO, full synthetic. This oil is not available in the US.
It is getting rave reviews on BITOG and a number of members are going out of their way to obtain it and stop using Mobil 1. The Esso product is made by Imperial Oil, a subsidiary of Exxon. It is a heavy duty diesel oil, suitable for gasoline applications.
UOAs and VOAs confirm this product is superior to Mobil 1. It does not shear to the same extent as Mobil 1 and is capable of providing longer OCIs, plus it costs considerably less than Mobil 1.
Bobo is offline
Old 05-15-2006, 08:05 AM
  #50
99grnmaxgxe's Avatar
Castrol GTX 5w30 b/c it's only $1 more than Quakerstate.
99grnmaxgxe is offline
Old 05-18-2006, 05:34 PM
  #51
hellfyre's Avatar
Originally Posted by Nazca
I use Mobil 1 for these reasons:
1. I can get it at Walmart
2. I am putting so many miles a month on my car right now that one oil change a month is enough for me
3. An associate who used to design engines for Fold told me that "anything they're using in Nascar, you should be using on your car"
4. I am familiar with Mobil's technical research center and have confidence in the products they develop and test.
Nascar eh.. Damnit I have been using unleaded fuel all these years. I should find a leaded fuel station and start using that. Might as well take out all right turn capabilities. I kid nascar fans
hellfyre is offline
Old 05-24-2006, 10:56 PM
  #52
fhs8860's Avatar
Do you guys recommend using Castrol SYNTEC 5W-30?
fhs8860 is offline
Old 06-07-2006, 09:31 PM
  #53
Roby1981's Avatar
Right now I am using Castrol Synthetic 5w30. But I will be switching to Mobil 1 soon cause I heard it is much better.
Roby1981 is offline
Old 06-11-2006, 11:19 PM
  #54
Torkaholic's Avatar
Not so fast. I'd recommend the 0w-30 German Castrol (gold or green, whichever you can find). But check out the BITOG link I'm placing below. This is to a UOA on a 350z using Castrol Syntec 5w-30. This report is hardly consistent with M1 being "much better." I've seen no M1 VQ35 UOAs substantially better than this. Really, you gotta do your own UOAs to see which works best for you in your particular engine, with your driving style, your environment, etc. M1 is fine stuff, but it's no more "magic" than it's good competitors. If you don't believe me, go study through the massive UOA sub-forum on BITOG. Be careful, it's addictive!
Oh yeah: http://theoildrop.server101.com/ubb/...c;f=3;t=003534
Look for mine on GC as well (my screen name there is "ekpolk").
Old 06-27-2006, 10:20 AM
  #55
mistermaximum's Avatar
Is it alright to switch to synth if you've never used it before (or aren't sure that it's been used before)?
mistermaximum is offline
Old 06-29-2006, 11:22 AM
  #56
ProV1's Avatar
i'm using maxlife 5w-30, coz i got those for free LOL
ProV1 is offline
  #57
ProV1's Avatar
btw i just picked up 6 qts of castrol syntec 5w-30 last weekend, on sale for 99cents/qt w00t
ProV1 is offline
Old 07-01-2006, 12:00 AM
  #58
TopSpeedNY's Avatar
nice!!!! which place carries it with that price....
TopSpeedNY is offline
Old 07-21-2006, 04:00 PM
  #59
THT
Throbbing member
THT's Avatar
Amsoil p2000 0W-30 FTW
THT is offline
Old 07-26-2006, 04:31 AM
  #60
anhhuy8's Avatar
royal purple 5w-30 motor oil for my o2 infiniti i35.
anhhuy8 is offline
Old 07-28-2006, 12:13 PM
  #61
Bruceman's Avatar
I used to use mobil 1 every 3-4k. After a friend told me about Amsoil I did my research and have now been using their 5w-30 for the past 10k miles and am a believer. Same goes for their gear oil, great stuff.
Bruceman is offline
Old 07-28-2006, 08:06 PM
  #62
kinzer1's Avatar
oil
Did anyone try Rotella T Synthetic or Mobil-1 Delo? Both are 5W-40 and "C" rated for commercial use (diesels, trucks and etc...)
kinzer1 is offline
Old 07-30-2006, 02:24 PM
  #63
clh288's Avatar
penzoil and change it every 2500
clh288 is offline
Old 07-30-2006, 03:25 PM
  #64
10 psi
glenmoormax's Avatar
mobil 1 syntec blend stuff 5W 30
glenmoormax is offline
Old 08-02-2006, 09:32 PM
  #65
sandeep's Avatar
i use castrol gtx 5 30 with lucas oil stablizer .. car runs silky smooth
sandeep is offline
Old 08-08-2006, 07:35 PM
  #66
progrocker's Avatar
Easy to find(at least the gold), great UOA's, the VQ loves this stuff. GC forever!.
progrocker is offline
Old 12-04-2006, 06:41 PM
  #67
rich in co's Avatar
My 92 seems to really like the Valvoline dino 10/30
rich in co is offline
Old 01-11-2007, 02:05 PM
  #68
stephenyi's Avatar
I use synthetic (Mobil 1 or Pennzoil Plat) cause I'm lazy and only change my oil twice a year.
stephenyi is offline
Old 01-15-2007, 08:10 AM
  #69
Y2K2Driver's Avatar
Redline 10w30 since 4k miles (currently at 58k)
Y2K2Driver is offline
Old 02-03-2007, 10:48 AM
  #70
KeithD's Avatar
I use mobil 1 5w-30 in my 93 SE, change it 5000km or 2x a year (don't drive much)
KeithD is offline
Old 02-03-2007, 12:14 PM
  #71
Bobo's Avatar
Given you live in Canada, you should be going to your local Esso bulk plant and buying Esso XD3 Extra 0w30 synthetic oil. It is superior to Mobil 1 based on UOAs and VOAs on BITOG and is only 2/3 the cost (or less) of Mobil 1.
Given you only drive about 10,000 kilometres/year, you would only need to change your oil once a year with the XD3 as it lends itself to longer drain intervals.
I just changed mine 11 days shy of one year. Although the oil only had 6,550 mostly highway kilometres on it, it was not at all dark in colour.
This product is not available in stores in Canada and not at all in the US.
Bobo is offline
Old 02-18-2007, 09:58 AM
  #72
sports8705's Avatar
i have 180000 miles so i use castrol GTX high mileage 5w-30
sports8705 is offline
Old 02-20-2007, 06:10 AM
  #73
Jason_03_Max's Avatar
mobil 1 syntec blend 5W 30 every 5k miles
Jason_03_Max is offline
Old 03-14-2007, 04:21 PM
  #74
peace's Avatar
Castrol Syntec and Mobil 1 have been my favorites.
peace is offline
Old 03-14-2007, 06:55 PM
  #75
Likes them corn fed
eckounltd287's Avatar
96 max, mobile 1 with fram filters,or nissan oem-every 7,000 miles. saw the new owner the other day, 235k and counting, still strong as when my father first bought it with 30k.
99 max Mobile 1 extended life with oem nissan filters- every 4,000 miles.
138989. and counting STRONG. just got my amsoil shipment today.
eckounltd287 is offline
Old 03-30-2007, 05:29 PM
  #76
TopSpeedNY's Avatar
Mobil Synthetic Oil 5w30 Only with Pureone oil filter or Mobil 1 filter.
Regards,
Mike
Old 03-30-2007, 07:04 PM
  #77
Proud Maxima Owner
Trajiksmax's Avatar
Mobil 1 fully Synthetic, change faithfully every 3k or 3 mo. what ever comes first.
Trajiksmax is offline
Old 04-06-2007, 08:26 AM
  #78
yehudi's Avatar
usually get the best available at the lube place
yehudi is offline
Old 04-12-2007, 09:55 AM
  #79
A33Black's Avatar
15w-40
Driving Area: South Florida
Oil: Any Major Brand Dino 15W-40 year round. Yes I know it's diesel oil, but it's also rated for Gas. The 15/40 spread has very little VI. I do 75% Highway driving, with 5K intervals. Check out the oil reports, 15/40 gets good results for hot areas.
Filter: OEM, now switching to Mobil M-110 after old stock of quality 9E000 is finished.
A33Black is offline
Old 04-18-2007, 11:25 AM
  #80
andrei3333's Avatar
Why does the Nissan Dealer use ESSO oil ?
andrei3333 is offline
Quick Reply: Oil Survey
