Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
10k miles for synthetic???
Old Aug 18, 2004 | 07:58 PM
cjden20thAE's Avatar
recently purchased mobil 1 to put in after 3000 miles but was stopped by midas cause they said i would waste my money. Oil still looks good when i check it, so how long should I wait with synthetic???
Old Aug 18, 2004 | 08:32 PM
deezo's Avatar
I run to 10000 with Mobil 1. I drive to many miles per month to keep changing at 3000 plus its a waste of money.
Old Aug 19, 2004 | 06:50 AM
SkoorbMax's Avatar
3000 is a waste, even with a cheap conventional. Your manual has as many as 7500 miles between changes, if you drive by schedule 2. That's with an OEM filter and a conventional oil. Since synthetic is better, even going by Nissan you could get over 7500 miles out of it. I personally don't quite have the guts to go 10k with my mobil1, though I rationally believe it to be fine.
Old Aug 20, 2004 | 10:01 PM
{-_-}'s Avatar
i'm gonna push my mobil1 to 9000 so i have a nice even 115000. i'm sure it can go to 10000 easily...
Old Aug 21, 2004 | 12:37 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
While member lab analysis supports extended drains with Mobil 1, keep in mind that Mobil advises that with Mobil 1, you can run the maximum distance recommended by the OEM. Even synthetic oil is cheap insurance versus the cost of an engine...if extendeding drains is the objective, I would feel safer using a product that is specifically formulated for that purpose...that way at least the manufacturer of the oil would be on your side in the unlikely event of a problem
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
hntwhttail
Sep 12, 2015 03:43 PM
pjgreek
Sep 9, 2015 09:30 PM
