Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
what is absolutely the best oil stop leak?
Old Jul 10, 2004 | 11:08 AM
michaelnyden's Avatar
what has worked very well for you guys?
Old Jul 10, 2004 | 02:42 PM
schernov's Avatar
Frequent maintenance.
Othewise, all of them have side effects....
Old Jul 11, 2004 | 04:11 AM
deezo's Avatar
Are you getting a leak or is the oil being burned normally? I noticed that you can lose oil into your intake system. This is the reason I'm going to install a oil catch can just ot see how much I lose.
Old Aug 1, 2004 | 11:30 PM
pharmboy's Avatar
how much oil do your cars lose b/w oil changes?
I ask this b/c I'm looking at a 98 max SE (91k) and the owner says it burns a qt. of oil b/w changes, and that it's done this since he got it. I saw no evidence of burning oil on the car or a drip in the driveway, but these are things that can be covered up.
Old Aug 2, 2004 | 12:15 AM
matty's Avatar
I never burn a drop...the transition between 5W and 10W between winter and summer I tend to burn a little but thats only 1/4 of a qt maybe...I will see if Im still burning after the next change
engine is safe at 1qt per 1000 miles according to VW...Our jetta burns alot but doesnt exceed that amount
-matt
Old Aug 2, 2004 | 09:55 PM
spirilis's Avatar
New seals.
Old Aug 3, 2004 | 12:41 AM
thnx for the sarcasm...captain obvious!
Old Aug 3, 2004 | 08:24 AM
SkoorbMax's Avatar
What oil, and how long between changes? I think that synthetic can be burned a little more than regular. My 00 runs on mobil syn and I think it goes through a half quart at least every 5k miles. My 97 is on mobil syn and goes through less it seems. I think that a quart every 3k is acceptable, as long as it's not much more than that.
To answer the original poster, I would personally not put an oil leak stop in my engine. I wouild use a high mileage oil before doing that. The reason is that they have balanced the oil properly with their own stop leak instead of throwing in "Freddie's Super-Stopper!" on top of your regular oil. Valvoline is one of the companies that has a high mileage oil. You could give that a go.
Other than staining the driveway, I think that a mild oil leak is not worth worrying about. I went through 30k miles on my 93 sentra with that, before getting rid of it recently. The repair was a $500 rear main seal replacement. I just kept an eye on the oil and lived with it. It never seemed to get all that much worse.
Old Aug 5, 2004 | 09:33 AM
johnny2kgle's Avatar
Here is a link for you. This stuff works and is not snake oil.
http://www.auto-rx.com/
http://www.auto-rx.com/pages/sealleak.htm
If you decide to buy the stuff, join their forum section to receive a member discount.
Old Aug 21, 2004 | 04:41 PM
baracus's Avatar
That is quite a bit of oil to be burning with only 91k...I would get the compression checked out before you buy it.
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
seesole
Sep 14, 2015 12:38 PM
ag90fox
Sep 9, 2015 12:22 PM
