Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
How much oil????
Old Aug 23, 2004 | 04:38 PM
cjden20thAE's Avatar
How much oil????
I know this has been answered a million times..but how much oil do u fill ur max with?? I put in 4.5 quarts mobil 1 synthetic...that ok????
Old Aug 23, 2004 | 06:06 PM
Zero Deuce SE's Avatar
I believe that yours takes 4¼ quarts with a filter change. It should be in your owner's manual.
Old Aug 23, 2004 | 10:29 PM
NismoMax80's Avatar
SuPeRmOd
that would be 4 quarts and one cup.
Old Aug 24, 2004 | 07:41 AM
SkoorbMax's Avatar
It takes me 4.5, so that's what i give!
Old Aug 24, 2004 | 09:28 AM
wrj's Avatar
wrj
I have a 6th gen and only changed the only twice so far. However, both times I followed the capacity reqms to the letter (4.25 qts) and it filled only to about half way up the dip stick. Then I add a little, drive, wait and fill a little more until it shows properly on the dip stick. I bet I'm at 4.5-5.0 qts before I'm done.
Old Aug 24, 2004 | 09:30 AM
MaximaPolak's Avatar
I put in over 4¼ but less than 4½.
Old Aug 24, 2004 | 11:47 AM
{-_-}'s Avatar
just check the dip stick and make sure it's within the levels on the stick.
Old Aug 25, 2004 | 07:42 PM
GeneYes_Se5spd's Avatar
dipstick in the 2k are F()CK1N6 useless, it p122es me of to no extent. The proper way to do it is to go to the last whole quart, for us itis 4, and then add little by little until it is good on the dipstick. EXCEPT my dipstick is completly USELESS. Next car i buy WILL have a working dipstick.
Gene
Old Aug 26, 2004 | 07:05 AM
SkoorbMax's Avatar
Gene
It is difficult to tell how much oil is in it. If the car is on even a slight incline/decline, for me it can show as much as a half quart off. I only ever check mine when it's cold and on a perfectly flat surface.
Old Aug 26, 2004 | 11:21 AM
schmatt's Avatar
Just use the rule of thumb that you do not want to overfill the car with oil. I wouldn't add more than 4.25 quarts, which is in the owner's manual. Maybe it takes a little more to completely fill it, but 4.25 will always get you in the right range of oil.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
