ATF in the 6 speed
ATF in the 6 speed
Well I tried my experiement and put Mobil1 ATF in my 6 speed. It shifts smoother (again) and appears to like the stuff. The Amsoil 80w-90 that came out looked funny as if it was full of metal dust or something. That of course wouldn't make much sense because the 6 speed has a big magnet inside it to attract the debris.
I did notice at first that my worn out 3rd gear syncrho was behaving far worse than before but after only a few miles it was working as it did before the fluid change.
This is going to require a longer term test for viability but for now the thing seems to be almost BMW smooth. Which is where I got the idea from, BMW uses ATF in their brand new manual gearboxes.
Originally Posted by IceY2K1
Hmmmn....what are the risks to using ATF instead?
Less shear strength and protection under high stress applications. Flows better in cold though. Most ATF's have a viscosity similar to 5W-20 motor oil.
It will be interesting to see how it holds up in this application!
Originally Posted by kcryan
it blew up 15 miles later and the flying gears hit and paralyzed the driver/poster...
Are the American Racing Chrome wheels there to prevent people from getting near your car, theft deterrent?
Originally Posted by MaximaSE96
just wonderign how the tranny is holding up
Originally Posted by nismology
Are there any additives on the market that could raise the viscosity and/or improve the shock-proofing properties?
Redline has a few:
http://www.myoilshop.com/ShkProof.html
Redline has a few:
I think he was talking about shock proofing ATF.
Some manuals are meant to use ATF from the factory. My one friend's Mustang's 5MT (2000) uses ATF, as does another buddy's Firebird's 6MT (1994). I was surprised, as I thought ATF would be a little too thin for gearbox applications. I also thought ATF to be similar in viscosity and weight to 5W-20.
Personally, if the car had 80W-90 in it from the factory, I would definetly not go to a dramatically thinner oil. I know I can't afford to risk having to replace a transmission.
If Matt really got the idea from BMW he would try to seal Automatic transmissions making the fluid non serviceable
Originally Posted by MrGone
Most domestics (tremec based) use ATF in their manual transmissions.
Lifetime ATF BMW transmissions are still serviceable.
knight_yyz
Nov 1, 2015 01:34 PM
