Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
How do i check my 5sp Tranny Fluid?
Old Sep 3, 2004 | 10:15 AM
Zipp028's Avatar
I was just wondering how do i check my 5sp tranny fluid? How do i know it needs a change? Autos have a dip.. what do i do?
Old Sep 3, 2004 | 10:39 AM
SkoorbMax's Avatar
You can't really know whether it should be changed without going simply by miles (anywhere from 30k to life on the fluid, depending upon which source you go by). Altnernatively you could send a sample off to get analyzed, but what's the point, since you might as well replace it if you're going that route. You could look at it and see how it looks also.
Anyway, to your question on how to check it. Get under the car (you'll need to jack it up or put it on ramps), and there is a bolt that takes a 1/2" ratchet. Undo that bolt, and put your finger in. Ideally the car should be level (so you can undo the bolt and then lower the car slowly). The fluid should come just up to the fill hole to the point where it would leak out if anymore went in.
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
