Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
can i run synthetic???
Old Oct 3, 2004 | 11:12 AM
gtmuggs's Avatar
Im wondering if anyone knows if i can switch to full synthetic mobil one.
my situation is i have about 111,000k one im currently running mobil highmilage synthetic blend and i want to switch to full syn mobil one im wondering if i have to many miles to switch.
Old Oct 3, 2004 | 03:01 PM
Max Atlanta's Avatar
IMHO you don't have to many miles. You should be able to switch to Mobil 1 and either a Mobil 1 or K&N filter with no problems. Your motor is just getting broken in..........
Old Oct 3, 2004 | 03:49 PM
Liquid_pjear's Avatar
Heh I have always run synthetic, in all my vehicles except my jeep cause she consumes oil. I have never had a problem with developing leaks. I have made the shift on cars with any where from 70,000 miles to 250,000 miles. I seafoam and flush my engines before switching to syn which has worked well so far.
Old Oct 3, 2004 | 04:31 PM
PLUMMAXSE's Avatar
You have been running a synthetic blend by running the mobil one stuff. If you don't have any leaks you should be fine.
Old Oct 3, 2004 | 04:45 PM
v6maximus's Avatar
It's cool to switch to synthetic, but once you go there there is no way back...
Old Oct 3, 2004 | 05:26 PM
MAXorBUST's Avatar
what are soem advantages to running synthetic?
Old Oct 3, 2004 | 07:32 PM
gtmuggs's Avatar
i think you engine runs more efficient and cooler better gas milage and longer intervals between oil changes and there could be more these are a few i know of.
Old Oct 4, 2004 | 05:08 AM
SkoorbMax's Avatar
You should be fine switching now.
It's not true that you can't go back after going to syn. Mobil claims that you can switch back and forth to your heart's content and they are fully compatible with each other (syn and dino).
The advantage to syn is that it withstands age much, much better. It doesn't break down as normal oil does. Of course, you can't keep it in there forever, because even though the oil itself may be perfect thosuands of miles later, it's got a bunch of junk in it (metals and carbon by products), so it does need to be changed. But, it will go longer than conventional between oil changes, and due to its robustness it will also lubricate better, on a consistent basis. So, better engine wear (ie. less), and very minimally slightly better gas mileage (on the level of 1%, so not really worth mentioning).
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
pjgreek
Sep 9, 2015 09:30 PM
