Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
A Little Seaform works
Old Nov 1, 2004 | 06:38 AM
blkmaxz95's Avatar
This weekend I tried using Seaform - Deep Creep. I sprayed some into the spark plug holes...and into the brake booster. >Poof>>> A cloud of smoke came out of the back end. Much to my amazment, as all males are amused by things like that, it remained cloudly for at least 10 minutes. Rev'ed the engine to 3000 rpms and waited for just a minute. More smoke. Then, I did a second treatment into the brake booster to the injectors...more smoke. I would natrually assume that the smoke is carbon being burned off.
I cleared my codes and received a new one, O2 sensor, frontside. I guess I will need to clean it.
I also received the KS code and the EGR valve code. I am going to replace them since now I am getting cruddy gas mileage. Even after cleaning the injectors and piston areas. I have gapped my spark plugs to 1.1/ .043 for the Bosch plat. spark plugs. Should I go to .044?
Old Nov 1, 2004 | 10:38 AM
Jatan's Avatar
You might wanna go with NGK copper or platinum plugs gapped to .044"
Don't replace the KS until you fix the other stuff first since it might be fine. EGR and SeaFoam thing: http://forums.maxima.org/showthread.php?t=350400
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
