Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Old Nov 8, 2004 | 02:45 PM
sunysb83's Avatar
just checked my power steering fluid the other day and it was quite below the cold min, just wondering what brand fluids you can use that is equivalent to the dexron III that is recommended
Old Nov 8, 2004 | 07:03 PM
RA030726's Avatar
I'm nutty for Nissans
i need the same thing. Motorvate says use dexron II or III depending on year and I cant find my haynes....
Old Nov 8, 2004 | 07:09 PM
RA030726's Avatar
i have a 96 owners manual, states dexron II or equivalent.
Old Nov 9, 2004 | 02:52 PM
RA030726's Avatar
wow the answer has been in the stickies all along :
Old Nov 21, 2004 | 03:35 AM
mrbill's Avatar
Power Steering Fluid…Still Confused
Did read the “Stickies” - "Power Steering Fluid Removal and Replacement"... After emptying the reservoir…“Replace with Dexron II or Dexron III depending on the year of the car”. “Procedure will only change about ½ of the power steering fluid”
Is it ok to use Dexron III (or Dexron III synthetic) when the “book” recommends DexronII (when you know the end result will be a half and half mixture of II & III and the “III” may be synthetic)?
(Seems the ATF manufacturers claim Dexron III and Synthetic Dexron III is compatible with Dexron II)
Old Nov 21, 2004 | 05:24 AM
Greeny's Avatar
¯\(°_o)/¯
Dextron III is the equivalent of dextron II. Just use III,it won't hurt nothing.
Old Nov 27, 2004 | 08:41 AM
sterlingmaxima's Avatar
i use prestone very good
Old Nov 27, 2004 | 10:23 AM
mrbill's Avatar
Did you use Prestone "Power Steering" fluid?? I looked Prestone "but" found it is not the receommended fluid - Dexron II or III ATF.
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
