Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
ATF Service on Max
Old Dec 16, 2004 | 03:24 PM
compnurd2K2MAX's Avatar
ATF Service on Max
Ok i have about 40k on my 02 max and have not touched the ATF. I am planning on doing a complete flush in 2 weeks and put that Amsoil fluid in. is there a tranny filter that should be changed as well and which brand? Also what is the correct type of Amsoil fluid i should use and does anyone have an idea of how much i will need. thanks.
Old Dec 18, 2004 | 12:59 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
there is not a tranny filter but a screen. if you drop the pan then you can clean the screen or replace it if its damaged. any atf should work as long as its mercon/dexron III compatible. if you using a flush machine then you will need 10-12qts but a drain and refill and dropping the pan should yield around 5-6 quarts.
my03maxima
Jul 28, 2024 07:40 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
