Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
should i use redline for notchy feel?
Old Dec 23, 2004 | 09:36 PM
MaximA StyLeZ's Avatar
i had my new clutch in for about 2 months, and prior to that i had a grind in 3rd in the higher rpm's (mainly shifting fast), and in cold mornings hard to get into 2nd until car warmed up, and overall really notchy gears,. So my clutch went, and i figured a new clutch would help. it did a little, but it still is rather notchy and still same problem in the mornings with 2nd. Really dont know if this is a common maxi problem, (i heard it was)? but do you think Redline would fix these problems?
Thanx
Old Dec 24, 2004 | 09:39 PM
bump guys.. i need some help on this
Old Jan 1, 2005 | 04:16 PM
jay929rr's Avatar
hey try going to bobistheoilguy.com and you'll get way more responses, those guys know their oil. I would think it would definelty help, i got it in my civic and it is a bit smoother.
Old Jan 1, 2005 | 06:28 PM
Virus's Avatar
It probably won't fix the problem, but it may help. You can also try Amsoil. Amsoil is a tad slicker.
Old Jan 2, 2005 | 09:42 AM
johnny2kgle's Avatar
Good advice. You might try searching the BITOG section GearOil Trans, etc.
I believe that some folks have mixed 50/50 the Redline MT90 and Redline MTL for smoother cold weather performance in Hondas. I am not sure about Nissans, though. The MTL is GL4 rated so you are fine with the specs and it is thinner than the MT90 (70w-85 vs. 75w-90).
Old Jan 4, 2005 | 01:03 PM
RA030726's Avatar
I'm nutty for Nissans
i have mt90 and it feels worse to me than what was in there. i have a short shifter so that could be some of the reason, but i can feel a difference between the oils. i dont like the mt90. i mixed mtl and mt90 for a friend, his G20 shifts nice.
Old Jan 5, 2005 | 10:50 PM
SSurfer's Avatar
I use it for my auto frontier
Old Jan 6, 2005 | 07:39 AM
bladerunr's Avatar
Trying the Redline certainly can't hurt. I'm using it and I like it. It is an $8 per quart investment that is worth a try.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
