K&N Filter Test
K&N Filter Test
I found a site where a K&N filter was tested against several different brands. Read the findings - under air filter test.
www.bobistheoilguy.com
This is not an air filter they are testing out...it's for OIL filters!!! and the best two seem to be the K&N and Fram that were tested. The testing isn't scientific enough IMO to prove which oil filter will be the best. It doesn't appear that they are keeping all of the variables the same. But for what the test is worth it appears that the two filters have the least amount of resistance inside of them.
This could be regarded as good or as bad. If there is more resistance perhaps the filter is doing a better job filtering out debris in the oil. I don't know enough about the topic of oil flow, but i would imagine you want enough oil to flow through so that you don't run into problems.
That's my 2 cents let's see what others have to say
You don't suppose that using an after-market oil filter will cause issues with warranty if you have an engine problem relating to oil / lube issues?? Guess that's why I've always used OEM Nissan filters...
the reason why I'm asking 'cuz I'm about to get K&N filter & oil filter
Check out this guys website...it's about sentra's. According to bob the oil guy from the link above he works as an engineer for Nissan. So I trust himhttp://www.sentra.net/tech/garage/en...d%20Lubricants
Originally Posted by mvb4704
Is this true ? does anybody else agree what he just said ?
Originally Posted by Virus
While he may be somewhat knowledgeable, he is too opinionated. Although Mobil 1 is a fantastic oil, Amsoil generally always comes out on top. He also states that Nissan OEM filters are the best and that is definately not true. Mobil 1 and K&N filters are far superior in all the filter tests I've seen over the years.
Selecting the correct oil filter
Your new NISSAN vehicle is equipped with a high-quality genuine NISSAN oil filter. When replacing, use a genuine NISSAN oil filter or its equivalent for the reason described in "Change intervals".
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
