Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Tranny Flush/????
Old Apr 25, 2005 | 04:54 PM
NOCturnalI30's Avatar
Tranny Flush/????
I have 85000 miles on the car and a VB mod done to the tranny, I bought the car with 75000 miles on it. Im not sure if i should change the tranny fluid or not. Should i do a flush or not i feel a lil more comfortable doing a drain and fill actually. I also wanna do it before i hit 100,000 miles please help thanks
Old Apr 26, 2005 | 02:59 PM
kcryan's Avatar
I have 77k miles on mine and i just did a drain and fill in my driveway, i filled it back up with M1 Synthetic ATF, Shifts great but i plan to do this again somtime soon to get more fluid out.
Old May 10, 2005 | 02:15 PM
VEvolution's Avatar
I miss my VE
1)warm up the car to operating temp
2)pull the dip stick out
3)wipe it with a clean (perferably white)lint free rag or bounty paper
4)place the dip stick all the way till its in place, and pull it out again. place the dip stick over a clean area on the rag and examine the color and smell of the fluid... if it looks brown, its no good. if it contains any metal peices, frictional materials, or looks or smells burnt, its not good. wipe clean, insert dip stick back in place, go online and let me know.
normally, transmission fluid should be changed every 30,000 miles.. and if im not mistaken every 2 years, but should still be changed every year to be safe
Old May 10, 2005 | 03:25 PM
Its brown but its not smelling burnt and when i wipe it on a bounty it then has a ver very slight red tint to it....drain and fill it with synthetic??
Old May 10, 2005 | 04:26 PM
VEvolution's Avatar
I miss my VE
well, the fact that its brown shows its old and used.. yeah, it needs to be changed. its good that it doesn't smell burnt tho, thats a plus.
as for the synthetic, i have no clue. i actually didn't hear about anybody using synthetic oil in the transmission. anyway, i think it would be best for you to use the recommended ATF in your owners manual, or FSM.
btw - next time you check your tranny fluid, its recommended that while you hold the brake, move your shifter through all your available gears to get the tranny fluid goin more. i guess it gives a more accurate reading of the level. sorry, i didnt mention it before.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
