Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Crush washers needed for M/T fluid change?
Old May 22, 2005 | 08:36 PM
EdL97SE's Avatar
Hi...are there any crush washers for the fill and drain plugs that need to be replaced when doing the manual trans fluid change?
Thanks.
Ed.
Old May 24, 2005 | 04:52 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Flat washers on my 2k2. IIRC it's the same for the 4th gens.
Old May 24, 2005 | 05:48 AM
EdL97SE's Avatar
Thanks...I'll make sure I have a few on hand when I change the fluid.
Ed.
Old May 24, 2005 | 10:09 AM
BEJAY1's Avatar
Conecarver
I've never seen any washers on my '97. I'm draining out through the neutral pos switch and filling in the regular hole.
Old May 24, 2005 | 08:29 PM
matty's Avatar
There was NO washer on my drain bolt from my 96' MT so I didnt bother adding one....its not leaking so its not a big deal...I change it every two years or so
-matt
Old May 25, 2005 | 04:31 AM
EdL97SE's Avatar
Thanks all for your responses.
Old May 26, 2005 | 01:20 AM
SilverMax_04's Avatar
My 6th Gen Max had a flat washer on both. The instructions I was following said to replace them, but the ones on the car looked exactly like the new one I bought, so I reused the old ones.
smplyamzng
Dec 13, 2015 01:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
RealityCheck
Aug 5, 2015 06:18 AM
