Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
longest interval between oil changes
Old 08-28-2005, 01:39 PM
kenny's Avatar
What is the longest interval for oil change and believe your Max is still ok? I only drive on weekends and I have 13k miles on my 03 Max now. The last time I changed oil was March 05, but I only added about 2k miles since. I guess I will change oil over the Labor Day week when I am off
kenny is offline
Old 08-28-2005, 01:44 PM
The Definitive AE Master
Larrio's Avatar
that would depend heavily on what kind of oil you use.
Larrio is offline
Old 08-28-2005, 01:45 PM
大陆弟弟
n3985's Avatar
The *recommended* change interval for dino oil is 3000 miles or 3 months. But I'm sure if you don't drive much an extra 500 miles or a month won't hurt.
n3985 is offline
Old 08-28-2005, 01:49 PM
OhOhMax's Avatar
I've got 10K on this change so far... trying out that 15K mile Mobil 1 Synthetic stuff.
OhOhMax is offline
Old 08-28-2005, 01:52 PM
大陆弟弟
n3985's Avatar
I hope you've chnaged the oil filter during that 10k.
n3985 is offline
Old 08-28-2005, 01:57 PM
kenny's Avatar
I have been using the dealer for oil changes. I don't know what kind of oil they use. Wow, 15k with Mobile synthetic!? What much does that cost you?
kenny is offline
Old 08-28-2005, 02:00 PM
OhOhMax's Avatar
I think it was something like $38 for the oil and a Mobil 1 oil filter.
OhOhMax is offline
OhOhMax's Avatar
No need to.
OhOhMax is offline
Old 08-28-2005, 02:08 PM
大陆弟弟
n3985's Avatar
I know synthetics theoretically can last a good 15k, but can the Mobil1 filter really go that far w/o a change?
n3985 is offline
Old 08-28-2005, 02:10 PM
OhOhMax's Avatar
I guess I'll find out one way or another.
OhOhMax is offline
Old 08-28-2005, 02:26 PM
boondoxmax's Avatar
i go 5000k between changes and use castrol gtx. i use to use mobil 1 in my 02 but i dont believe syn is worth the extra money unless you change your oil less often
boondoxmax is offline
Old 08-28-2005, 03:17 PM
Rayn4est's Avatar
I went 8000 once, but I'm not proud of it. I was doing LOTS of highway driving at the time so I was on the 7500 plan. Now I stick to under 5K.
Rayn4est is offline
Old 08-28-2005, 04:41 PM
mdloops's Avatar
I never change before 6K miles. I have done this for years. Every 6K miles on synthetic. I also do not change my filter every 3K but I do every 6K
mdloops is offline
Old 08-28-2005, 04:49 PM
djsoniq's Avatar
OhOh I use AMSOIL full synthetic. You can go long intervals without changing the oil. I just did mine after 10k and it still looked really good. But you DO have to change the filter, at most every 5k miles. If you don't you could end up having serious issues in the end when the filter gets loaded with particulate matter and then stops working properly which WILL happen.
djsoniq is offline
Old 08-29-2005, 06:56 AM
big_bogus's Avatar
I use M1 and change every 3/3000. Synthetic is awesome, but it does not increase the interval between changes. The interval is set to 3/3000 for ALL oils because the oil becomes contaminated, detergents dissipate, and protection becomes reduced.
Check out Pat Goss. He is extremely knowledgeable about all car repairs and maintenance.
big_bogus is offline
Old 08-29-2005, 06:57 AM
silversurfersg's Avatar
just did 21k on synthetic in a year whoops. normally 10k is fine for synthetic but i didnt have the time to change it.
silversurfersg is offline
Old 08-29-2005, 07:23 AM
Bobo's Avatar
I am also a low mileage driver and have extended my oil changes on dino oil to 9, 10 or 11 months in the past. Mileage has been under 3,000 miles twice when I extended it this long. Two stealerships have told me to change the oil every 6 months because moisture can get in the oil when the car is sitting for extended periods. I am switching to synthetic oil after my AutoRX clean and rinse phases are over.
Look at www.lubecontrol.com. They offer a product, LC20, that helps to extend oil change intervals and cleans the engine. I would strongly consider buying some of that and trying it if you continue your present practice.
Alternatively, you should be changing your oil every 6 months.
Bobo is offline
Old 08-29-2005, 07:33 AM
Puppetmaster's Avatar
Every 5K miles, oil and filter.
I use Mobil 1 Synthetic 5W30 (23 bucks for 6 gallons from Costco) and OEM filter.
Puppetmaster is offline
Old 08-29-2005, 07:46 AM
Bobo's Avatar
Everyone is missing the point. He is a low-mileage driver and needs to change his oil more often than every 5K as that will extend him beyond a year.
The 3K, 3 month oil-change interval is a myth perpetrated by the oil companies and lube joints. Even severe service with a Maxima only dictates a 3,750 mile OCI.
I have to laugh at the idiots who are changing Mobil 1 synthetic oil at 3K, 3 month intervals - they obviously have more money than brains!
Just a suggestion, kenny: stop going to the dealer for oil changes. Buy a Nissan OEM filter from the dealer and change the oil yourself or get a friend to do it for you if you don't know how. Also buy a decent quality dino oil.
You are NOT a candidate for synthetic oil.
Bobo is offline
Old 08-29-2005, 08:03 AM
00Max00's Avatar
5000K oil change interval???!!! I'm wondering you have been in the world long enough to drive that much miles and having the chance to change your oil once. Your engine must be made by space alien's exotic aerospace material...
00Max00 is offline
Old 08-29-2005, 08:10 AM
Bobo's Avatar
I have used Castrol GTX most of the time but have never extended it beyond 4K. I strongly suspect that he is fine on Castrol GTX up to 5K provided that the car sees a decent amount of highway miles. I wouldn't go 5K on dino oil with mostly city driving.
Bobo is offline
Old 08-29-2005, 08:30 AM
Do I get a tax break?
njmodi's Avatar
Bobo - you missed his joke - boondoxmax stated 5000k as his OCI, he really meant 5k ...
njmodi is offline
Old 08-29-2005, 08:37 AM
Bobo's Avatar
It's still early here. Another cup of coffee is in order, lol!
Bobo is offline
Old 08-29-2005, 08:56 AM
boondoxmax's Avatar
yeah i know .
Old 08-29-2005, 09:16 AM
Bobo's Avatar
Stupid is as stupid does! It takes no time at all to drive through a lube joint. I suspect you didn't even change the oil filter.
Bobo is offline
Old 08-29-2005, 09:45 AM
boondoxmax's Avatar
Isn't synthetic just regular dino oil with some extra additives.....
Old 08-29-2005, 10:01 AM
Bobo's Avatar
No!
Bobo is offline
Old 08-29-2005, 04:56 PM
big_bogus's Avatar
I take offense to the idiot comment.
1) Manufacturers recommended maintenance is usually based on an expected life of 100,000 miles. I want my engine to last much longer.
2)For most vehicles, exclusive highway driving, 5,000 miles is a good number. Exclusive severe driving which includes beltway driving (beltway is not the same as highway driving) than 3,000 miles is absolutely the way to go. Also keep in mind it is never better to go longer, if there is any question of your driving always go with the severe driving schedule for your car.
3) I drive in traffic a LOT!!!
4) Are you jealous I can AFFORD it??? Just kidding, but I didn't appreciate the comment!
Old 08-29-2005, 05:34 PM
kenny's Avatar
Bobo, I appreciate your comments and guidance. I guess I will stick to the 6 month changing interval, as I rarely drive more than 3k miles between changes.
kenny is offline
Old 08-30-2005, 01:17 PM
dlee27's Avatar
Just do a couple of oil analysis and you'll find out why changing oil at 3000 miles is a waste of money.
dlee27 is offline
Old 08-30-2005, 04:43 PM
boondoxmax's Avatar
No!
I thought all oil started with same base stock and synethic got some different additives........
Old 08-30-2005, 05:53 PM
drock02's Avatar
I've always gone by the 3K rule...I ran synthetic in my mustang but really don't buy into the benefit. Frequent oil changes are an easy way to guarentee performance from a motor...I had a friend (with more money than brains) that bought a brand new toyota tacoma who decided to see how long he could go without changing the oil filter....blew the motor at 40K
drock02 is offline
Old 08-30-2005, 06:36 PM
mdloops's Avatar
BOBO - I know what you're saying. A LOT of people go OCD with maintenance and call EVERYTHING Preventative Maintenance. If the synthetic oil bottle's label does not look right they will only keep it in their car 1K miles and change it again. There is no eact black and white on this one guys. The only true way to tell is to visually inspect your oil at specific intervals and determine what is best for you. Personally I will never keep a car more than 100K miles anyways so I could care less. I change it every 6K miles and that to me is being on top of things. Would I ever change any car's oil at 3K miles intervals again? Never in a million years. The oil products out today are very different from the dyno oil. If you feel the need to change every 3K or so do it. I would however put money down saying the difference in longevity of an engine that is changed at 6K miles compared to 5K would be almost non existant.
What people seem to forget is how you DRIVE your car is the GREATEST factor in how long your major components will last. I could change my oil every 10K miles and my engine would probably last longer than somebody elses who changed their every 1K miles yet felt the need to redline their engine and show it 6K RPM revs on a regular basis. The BEST preventative maintenance you can do is to NOT BEAT ON THE CAR.
mdloops is offline
Old 08-30-2005, 06:49 PM
Isn't that a girl's name?
Morgan06's Avatar
you're supposed to change the oil?
Morgan06 is offline
Old 08-30-2005, 10:37 PM
JohnnyJet's Avatar
5k mobil 1 and filter.
JohnnyJet is offline
Old 08-31-2005, 05:55 AM
I Know Kwaliti
igzy's Avatar
Mobil1 5W30 oil every 6K, OEM filter every 3K...
igzy is offline
Old 08-31-2005, 07:45 AM
drock02's Avatar
How do you change the filter but not the oil??? Filter every 3K, oil every 6K. You must be really fast LOL!!!
drock02 is offline
Old 08-31-2005, 08:25 AM
I Know Kwaliti
igzy's Avatar
I do it on a cold engine and add only about 1/2 qt of oil... As you can see only a little bit comes out when you take off the filter and whatever oil is in the filter...
Reason for this: Mobil1 is good for at least 6K, but filter is not. Almost all filters are good for 3K maximum. Though, I did not have a chance to try out Mobil1 filter as they are not available in Canada yet...
igzy is offline
Old 08-31-2005, 08:31 AM
Bobo's Avatar
That's utter nonsense!. Any decent oil filter is good for more than 3,000 miles. Have you ever cut one open with a hacksaw and inspected it?
Since you live in Canada, you should strongly consider switching to Esso XD3 Extra, 0w30, full synthetic available only at Esso bulk plants. Its showing better UOAs on BITOG than Mobil 1 and is considerably cheaper.
A guy with a taxi fleet in Saskatchewan did a UOA on one of his taxis after 40,000 km and the XD3 was still good to go for quite some time.
Just avoid Fram oil filters.
Bobo is offline
Old 08-31-2005, 09:12 AM
mdloops's Avatar
I would contenst that most good filters will last at least 6K miles.
mdloops is offline
Quick Reply: longest interval between oil changes
