Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Mixing synthetic oils?
Old Oct 15, 2005 | 08:00 AM
DDub's Avatar
Can I mix different synthetic oils? For example, Amsoil TSO and Mobil 1.
Old Oct 15, 2005 | 08:06 AM
Bobo's Avatar
You can do anything you want, but why bother mixing synthetic oils? A more common practice is to mix synthetic oil with dino oil to get your own syn-blend. Syn-blends being marketed today are only in the order of 10% synthetic oil and are a waste of money.
I don't know what advantage you are trying to achieve by mixing synthetic oils, unless its only because you don't have enough of each type for a full oil change and even then I wouldn't do it.
Old Oct 15, 2005 | 08:35 AM
kcryan's Avatar
you can, but i would just run em straight, they may have certain additives that get angry with each other....
Old Nov 2, 2005 | 07:05 AM
Ammi's Avatar
350 Detroit Muscle
I mixed bunch of times. When I ran out of Amsoil during an oil change, I went to the store and bought some Mobil1 to use.
Old Nov 5, 2005 | 02:31 PM
steven88's Avatar
Need A Light?
yes you can mix synthetic/synthetic or synthetic/dino...no matter what brand...
and there is no harm in going back to dino oil after using synthetic...it also applies to the other way around
Old Nov 6, 2005 | 12:39 PM
SilverMax_04's Avatar
As a general rule, you will be better off by using the same oil from the same manufacturer. But rules are to be broken. I got some cheap Mobil 1 synthetic 0W30 that I mix in with Mobil 1 synthetic 5W30 oil when I change oil for going into the winter (I don't use the lighter weight in the summer).
I also had some, but not enough of, an earlier synthetic oil that I mixed (one time) with Mobil 1 of the same weight when I decided to start using Mobil 1. Was not going to just leave the old oil (no longer available) sitting on the shelf, so I used it.
Most of the time, you should probably follow the rule above, but the call is yours. If you don't you probably won't hurt anything. Why is this a good rule to follow: different motor oil manufacturers use different addative packages for their oils. The difference in these packages could (but not likely) cause some problem, more likely if you continue to make these blends with every oil change.
If you don't have enough Amsoil for a change, you are better off making up the difference with Mobil 1 than not filling the crankcase so you are less than a quart below the full line.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
