Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Those who have used auto-rx...
Old Jan 16, 2006 | 09:32 AM
FormorAccordMan's Avatar
Is this stuff supposed to look like dirty oil to begin with? I oped my bottle andit looked like used/nasty oil. Sorry for my iggnorance. Just wanted to know if the stuff inside was normal....
Old Jan 16, 2006 | 10:55 AM
DrKlop's Avatar
Driving is the next best thing
yap, that's exactly the way mine looked. I got suspicious at first but put it in afterwords.
Old Jan 16, 2006 | 11:08 AM
How is it working out for ya? where are you in your stages?
I have only 100 miles into the first cleaning phase and I swear my car is more responsive. My car feels like it has more torque. I am getting very excited about the prospect of this product.
Old Jan 16, 2006 | 03:05 PM
DrKlop's Avatar
lol, as of now I'm like 40 mils into the first phase.
Old Jan 17, 2006 | 11:50 AM
Bobo's Avatar
I have completed the 1,500 mile clean phase and am about 1,700 miles (out of 2,000) into the rinse phase. My engine is so quiet I literally can not hear it at idle and the car seems more responsive.
I am switching to synthetic oil for the first time following completion of the rinse phase.
I endorse AutoRX!
Old Jan 17, 2006 | 05:09 PM
Kolyan's Avatar
i don't realy have any problems with my engine and i am kinda afraid to use auto-rx.....should i be? can it cause problems?
i have 98k miles and have been using syn. mobil 1 since 53k
Old Jan 22, 2006 | 05:00 PM
2002 Maxima SE's Avatar
I just finished the clean phase on my 1993 Mercury Sable with 170,000 miles. So far:
1)Engine is much quieter
2)Throttle response is better
3)Leaks got worse (expected)
4)Smoking got worse (expected)
5)Head gasked leak got worse (expected)
I'm about 40 miles into the rinse phase and the leaking/smoking has sub-sided. Will probably do another dose this summer.
Old Jan 22, 2006 | 05:10 PM
HUH? the leaks got WORSE? WTF?! and why was this expected?
Old Jan 22, 2006 | 05:29 PM
rsly33's Avatar
Because all the sludge keeping the leaks closed was removed, after ARX removes the sludge the leaks will open up. Not a case for every engine though
Old Jan 22, 2006 | 07:11 PM
njmodi's Avatar
Do I get a tax break?
I used ARX, did the high-mileage routine (2 cylces, 1500 mile cleaning and 2000 mile rinse for each cycle).
Don't notice anything different ... didn't do squat for the varnish ... but it's known that it doesn't work well on varnish on aluminum blocks...
Old Jan 22, 2006 | 08:06 PM
alanalan's Avatar
if there a leak, are you suppose to anything with the leak or just leave it alone?..i read in the auto rx website it was suppoes to prevent leaks?
Old Jan 22, 2006 | 08:37 PM
njmodi's Avatar
It won't prevent leaks... if you have a leak that is being masked by sludge filling it in, ARX may wash away the sludge and so the leak will show up. Similar to the effects of switching to synthetic at a high mileage.
Eventually ARX is supposed to soften rubber gaskets, etc. helping them seal better, so the leak that it made evident, can sometimes disappear, since the leaking gasket starts to seal better after being softened.
Old Jan 23, 2006 | 09:35 AM
Bobo's Avatar
You should do the AutoRX treatments back to back and not wait for the summer.
Old Jan 23, 2006 | 11:34 AM
alanalan's Avatar
so i guess leave the leak alone if there is a leak? am i correct?
Old Jan 23, 2006 | 04:15 PM
Kolyan's Avatar
if u have a leak it can get worth w/ auto-rx treatment or auto-rx can fix it by lubricating seals
Old Jan 23, 2006 | 05:42 PM
njmodi's Avatar
If there is a leak, if it's severe, fix it, otherwise leave it alone. Pretty simple.
Old Jan 25, 2006 | 07:44 AM
alanalan's Avatar
when u change the filter in the beginning, should you use a cheap oil filter or a more known one? thanks
Old Jan 25, 2006 | 08:37 AM
njmodi's Avatar
Use an OEM filter - can't beat it for 5 bucks a piece. You want to use a good filter to catch any crud the ARX loosens/dissolves.
Old Jan 25, 2006 | 02:29 PM
Tennisjon2002's Avatar
supertech filters from walmart are actually pretty good and they are dirt cheap
Old Jan 25, 2006 | 05:03 PM
alanalan's Avatar
cool, i'll guess i'll probably use one of those, anyway do you know where you can buy the m1 filters, i cant seem to find them.....thanks
Old Feb 1, 2006 | 08:44 AM
Phoenix's Avatar
Lives in a Maxima
OK, so I've checked out BITOG, I've looked at the auto-rx website... I think I'm going to do it.
They recommend 2 applications for cars over 100,000 miles... Would this be sufficient for cars over a quarter million miles also? Should I just increase the maintenace dose to 3oz as recommended for high-sludge engines? Or should I repeat the whole cleaning process after a 10 or 20 thousand miles?
I looked and I really couldn't find any testimonials for cars with >250,000mi
Old Feb 1, 2006 | 04:24 PM
Bobo's Avatar
In your case, you should do the AutoRX applications back to back. Following the 2 AutoRX clean and rinse phases, you may want to consider the maintenance dose. Alternatively, look into LubeControl LC20 on BITOG or www.lubecontrol.com
I haven't used LC before and am just finishing up my inital AutoRX rinse phase, then switching to synthetic oil. I may consider LC after I am through my first synthetic oil OCI.
Old Mar 10, 2006 | 11:52 AM
DrKlop's Avatar
I've just bough Castrol GTX to use during the rinse cycle, but than it occured to me: isn't it better to use the oil that does not have any additives?
Can anyone comment on this? Is it better for me to return Castrol and get some cheep oil with fewer additives?
Old Mar 10, 2006 | 04:58 PM
Bobo's Avatar
Stay with the Castrol GTX. It's a good quality oil and is only going to be in there for 1,500 miles. I ended up using Pennzoil 5w30 for the first time for my rinse phase and have now switched over to synthetic oil for the first time at 63K (Esso XD3 Extra, 0w30, PAO).
Old Aug 16, 2009 | 07:07 AM
kisas's Avatar
then why the smoking/leak subsided when entered rinse stage?
