A/T transmission oil drain plug
I'm about to run to the store to get a tool to open the plug. Just making sure to get the right tool. I'd like to confirm, before this thread gets deleted.
I saw a plug (not on the black oil pan, but on the trans block) pointing down and toward the front. It has a hole that you need a tool to fit in there to turn it. Is it the right place to start???
allen key wrench
get a big one that's all i know. lol
it's pointing out towards the front of the car. and it's silver like you said.
and it's on the TRANSMISSION.
and p.s. don't be like me and ruin your tranny. make sure you fill it with matic-k nissan OEM fluid only.
peace out
peace out
Do you have the four speed. If so check the manual I believe the four speeds use a different type. I guess you probably know if you are using the right fluid. I am getting ready to change mine but I have the four speed ****. Good luck and let us know how it goes.
Piece of cake !
This is the most pleasant thing one can do for the Max. I bought the 10mm hex key and use my regular wrench. The plug went right out of with minimal force. I guess one can do without the wrench, using regular hex key. Only took me 10minutes (I've been prepared to do this).
The oil is blackish and not that pinkish (put a few drops on a cleanex). The new oil looks almost like blood. I don't care what people says, I will drain/refill every year from now on. The oil doesn't look too good after 29.5kmiles. Just by mixing with some new oil, I have to do this often. I drove for about 30minutes to warm up, and only 3 quarts came out. The only pain is the $9.99/quart ripoff. I think it's so much easier than the regular plug on the 4spd A/T. The head on that plug is about 2mm thick, it's hard to keep the wrench socket stay on.
Originally Posted by nick wolff
allen key wrench
peace out
peace out
Originally Posted by Zero Deuce SE
I used Amsoil synthetic ATF in mine at 30K miles and haven't had any problems. I'm nearing 50K miles.
Deuce, he's a 6th Gen... Only Nissan K in that baby... We 5th Gen can still play around with ATF brands...
MaxFan, this is the best preventive maintenace you can do for your tranny. Once a year (maybe even twice if you get a nice tax refund) is a good plan.
i went to MOBIL 1 ATF SYN and it seems smoother, but once in a while I get wierd feeling in tranny like it's hunting or shuttering. It's chirped once or twice, which was kinda odd.
I d k if i should go to regular mobil ATF or do ATF SYN.
All righty then.
). Give it a try and see hoew it works for you...
After battling with inconsistent shifts with Mobil1 for several months, I decided to follow a recommendation from another forum of removing the neg cable of the battery overnight. The TCM has a "Memory Battery Backup" pin which gets power from the battery all the time. By disconecting the battery, you're causing the TCM to "loose" any parameter values learned and forcing the TCM to relearn them as you drive. After doing it, the tranny feels better than ever. It will cost nothing (just having to reprogram your radio stations
). Give it a try and see hoew it works for you...that is interesting.. i have a 97 and i'll give it a shot. i also gotta reset my CLOCK !!!!
hahah thanks.
hahah
thanks.
hahah thanks.
sctludwig
Sep 1, 2022 01:32 PM
97_GXE
20
Sep 17, 2015 08:12 PM
markevans999
Sep 10, 2015 04:29 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
