royal purple atf testimonial
wow, thats all i can say. after draining and refilling my tranny a good 3 times with royal purple atf wow it shifts soooo smooth you barely even realise it shifted. although sometimes i still have the hard 1-2 shift... any resolutions on that? is that normal for the maxies?
hey guys. I just had my tranny flushed @120K, (changed transfluid at 70K) with regular ATF. does the royal purple really make a differnce for the tranny. Last year in the lab (working on masters in engineering), we tested royal purple oil vs. castrol, mobile 1, and the others and royal purple died early in the test. Castrol and Mobile 1 were at the top with Moble 1 beating Castrol (but it was so close it was negligable). I have heard from others that the tranny fluid is really good.
thanks
thanks
thanks
thanks
Originally Posted by maximaownsyou
i drained it and refilled it twice in a row with a 15 minute car run in between so it would mix with the torque converter and then drove on it for 1k miles and did the 3rd drop and refill
royal purple synthetic ATF which is now $9 a quart... 15 quarts total ... about 4.5-5.0 per drop and refill so it was like $120-$130 .. for every 60k miles and fluid this good... well worth it. we spend that much on an intake dont we? i bet you feel better after the fluid then after the intake
