Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
castrol gtx or castrol high mileage
Old Mar 16, 2006 | 07:10 PM
wutsup
hey guys my car has over 213,000 miles on it. should i use castrol high mileage or just the regular gtx oil?
Old Mar 16, 2006 | 07:15 PM
DrKlop's Avatar
Driving is the next best thing
I'm not an expert but as far as I know "high mileage" oil is not for high mileage engines but for the engines that are about to die with worn out rings, leaking seals and head gasket.
I wouldn't use high mileage oil unless you got leaks or your car consumes oil.
Old Mar 16, 2006 | 07:20 PM
wutsup
so.........if you can see smoke coming from the engine after running it for a while i should try the high mileage stuff? it burns oil but not a lot
Old Mar 16, 2006 | 07:45 PM
DrKlop's Avatar
Yeah, I guess you should try it in this case. Let's see what others have to say.
Old Mar 16, 2006 | 08:14 PM
d00df00d's Avatar
Old enuf to pick his own gears
If you'd like to try the high mileage stuff to cut down on the oil burning, go for it. Just don't expect it to be as effective as addressing the real cause.
Old Mar 16, 2006 | 09:45 PM
DrKlop's Avatar
I don't think it worth rebuilding the engine at this stage. Most likely he needs new piston rings.
Old Mar 18, 2006 | 04:09 AM
BK1's Avatar
BK1
Hello
You have 213K miles? Just keep doing what you've been doing.
Old Apr 5, 2006 | 06:39 AM
max95q's Avatar
My friend has this issue. So if we see white smoke coming from the exhaust after the car has ran for a while he is in need of new piston rings? Hmm... I figured as much. Would that Engine Restore stuff help him out any while utilizing the GTX High mileage stuff?
Old Apr 5, 2006 | 09:19 PM
konak85's Avatar
You should use it, but it won't make much of a difference. Try to stay away from quaker state!!
Old Apr 6, 2006 | 12:41 PM
DrKlop's Avatar
nah, white smoke it probably from carbon deposits. Check if the car consumes oil and if black colored oil accumulates on the oil cap. If oil consumption is minimal and the oil cap is clean your piston rings are most likely fine.
Old Apr 6, 2006 | 04:06 PM
max95q's Avatar
Great thanks, Ill let him know that it could be just carbon deposits. Ill have him check the cap too.
Old Apr 12, 2006 | 11:34 AM
aamir's Avatar
Hey guys,
I just bought and used Castrol High Mileage engine oil and my car has 119,000 miles. This was my first time using it. For my next oil change, should I go to the regular Castrol GTX oil or stick with the High Mileage? thanks in advance
Old Apr 12, 2006 | 11:56 AM
nismology's Avatar
I vote for GTX. According to the stickies it's the best oil that Castrol makes.
Old Apr 14, 2006 | 06:39 PM
DrKlop's Avatar
Originally Posted by aamir
Hey guys,
Read post # 2 and you'll find out the answer on your own...
Old Apr 15, 2006 | 07:24 AM
nismology's Avatar
You're saying it like your post was based on empirical evidence.
Old Apr 16, 2006 | 01:42 PM
aamir's Avatar
Sorry about that, I guess I overlooked your post. I also think that I will be switching to the normal Castrol GTX
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
