sparkplugs?
NGK stock platinum (OEM) is the best....If you don't mind changing out the plugs more often, I say get the NGK coppers...they are much cheaper if you can't afford the plats right now
stock heat range is 5
I just replaced my OEM plugs (NGK Platinum) in my 98 at 75,000 miles. They looked a bit tired but the car ran flawlessly with them in there. The engine started and ran no differently with the new plugs vs the old. The fuel mileage is the same.. The NGK Platinums last a long time. There might be something better out there though.
Originally Posted by merovi
i just got NGK platinum at advanced auto for like $2 each. Are these different plugs? The dealership wanted $11 a plug when I called them.
Tha'-Max
Aug 30, 2015 01:14 AM
on stock heat range, though.
