Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Attn: those familiar with Amsoil synthetic manual tranny fluid!
Old Sep 20, 2006 | 07:02 AM
pbn85's Avatar
I have a 2003 maxima 6 m/t and my mechanic will be flushing the old tranny fluid tomorrow morning and will be using amsoil synthetic manual tranny fluid. I want to make sure he uses the right one. I checked amsoil.com and quite a few different kinds came up. Please tell me the correct one I need. is it
the synthetic syncromesh f1? He also said he will use 5 quarts but to the best of my knowledge, he should only be using 2.5 - 3.
also, whats the difference between gear oil and transmission fluid? Should I get that while I'm at it? thanks in advance.
Old Sep 20, 2006 | 08:32 AM
BigFly_2K2SE's Avatar
A manual transmission requires gear oil, an auto tranny takes transmission fluid (ATF). Our manual trannies require GL-4 spec gear oil, which is fairly difficult to locate. Amsoil MTG is the correct gear oil that meets this spec. The Redline equivalent is MT-90.
If you buy 3 quarts, you will have enough for a 5.5 gen.
Old Sep 20, 2006 | 08:58 AM
pbn85's Avatar
Im just confused b/c this says MTF -manual transmission fluid:
https://www.amsoil.com/storefront/Se...CategoryID=297
and then there is this:
https://www.amsoil.com/storefront/Se...CategoryID=298
its the 2nd link right?
Old Sep 20, 2006 | 03:15 PM
99se5speed's Avatar
SHIFT_up
You need amsoil GL-4 75w90 gear oil. It is one of the best gear oils on the market. IMO it exceeds redline, idk i used about 4 or so quarts in my 5spd.
Old Sep 21, 2006 | 06:30 PM
irish44j's Avatar
retired moderator
I've used both the Amsoil and Redline MT-90 (currently). I could tell no difference between the two, but both are an improvement over other gear oils.
Old Sep 21, 2006 | 07:06 PM
pbn85's Avatar
update: just got the fluid changed today..shifting is slightly better..actually no Im lying, its hardly noticeable. Maybe I'll notice the difference when it gets colder? I used Amsoil gl-4 btw.
Old Sep 22, 2006 | 09:23 AM
In all honesty, I have switched from Nissan OEM to Redline MT-90, then recently to Amsoil MTG and have not ever noticed any difference in my shifts. However, I rest easier knowing I have the best protection in Amsoil in my manual tranny.
The one thing I did notice was that the MT-90 was less stiff than Nissan OEM in the cold winters I experience at my location. I have not put the MTG through one of my winters yet (coming soon!).
Old Sep 22, 2006 | 12:08 PM
pbn85's Avatar
good to know ^....keep an update on how your amsoil holds up in winter
Old Sep 24, 2006 | 08:02 AM
d00df00d's Avatar
Old enuf to pick his own gears
The difference between MTF and MTG is mainly that MTG is made for transmissions that see significant shock loading, high gear tooth loads, and so on. That makes it more like gear lube in terms of formulation, which is why people sometimes call it that to distinguish it from other transmission fluids. MTF is for applications like Honda transmissions, which don't require that kind of robust formulation and are instead optimized for other things. Your transmission does require MTG, and if you had used MTF you would be risking a lot of premature wear and tear.
Old Oct 16, 2006 | 11:37 PM
pbn85's Avatar
ohh...thats great to knoe..thanks for pointing out the difference
Old Oct 17, 2006 | 06:32 PM
turkey72's Avatar
Just changed to the MTG from the stock fluid. Big difference in shift smoothness.
Old Nov 27, 2006 | 06:15 PM
Well, I put my Amsoil MTG to a pretty decent cold weather test yesterday morning and I would have to say it passed with flying colors.
It was -33C (-27F) when I went out Sunday morning and all I could feel was that the shifts were slightly stiffer-than-normal. Barely noticeable. Pretty impressive considering the temperature.
I wish I could say the same for my clutch.........I could hardly even push it down!
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
