Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
radiator cleaners
Old Apr 3, 2007 | 01:56 PM
lobewiper's Avatar
radiator cleaners
Hi all
Any ideas on a good brand of radiator cleaner? I have some mild scale in my 04 SL. I've always tossed in a can of Prestone cleaner every two or three years before changing the anti-freeze, but never really noticed whether it had much of an effect. Who's had good luck with this task? Or, is it not really a do-it-yourself thing? Also, some think distilled is superior to tap water--does this sound right? Thanks much...
Old Apr 4, 2007 | 06:17 PM
madmik's Avatar
The Prestone cleaner is probably effective if you follow the instructions but how do you get scale in a rad??? Well water?? Should use distilled or deionized water. My wife's Corolla is 14 years old. Pop the cap and the inside looks new.
The Prestone 50/50 mix use demineralized water. It must be a plus if they use it. Distilled water is $1.50 a gallon at the grocery store. That's all you need for the Max, plus one gallon of Prestone.
Old Apr 5, 2007 | 07:18 AM
I VIK I's Avatar
how often should this be drained?
Old Apr 5, 2007 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
Do you have an owners manual?
Old Apr 5, 2007 | 07:43 AM
4MySwee's Avatar
Nmexmax,
Owners manuals don't cover everything. Mine doesn't even tell me when to flush my tranny. Unless of course I have a CVT. My car was made before they introduced the CVT's for it.
Old Apr 5, 2007 | 07:45 AM
NmexMAX's Avatar
dot dot dot ...
But, the information on where to get the proper service manuals/schedule you need is in the back of the owners manual.
Old Apr 5, 2007 | 07:55 AM
I VIK I's Avatar
You know I dont understand this about people, we are all here to help each other out, I ask you a general ?, you go out of your way to tell me to look at my manual. It takes less enery to say every --,000 miles or every - months I mean if manuals covered everything then why do we need maxima.org? Might as well shut it down right?
Old Apr 5, 2007 | 08:02 AM
NmexMAX's Avatar
dot dot dot ...
I change mine every 30k miles . Whether the manual says it or not. Should be done twice/year. IMO.
From the manual in my 95, it states to replace it at 60k, then every 30k after that, or 24 months. But, I can't remember when the last time was that someone actually took my advice, so..
Old Apr 5, 2007 | 08:36 AM
lobewiper's Avatar
Yes, my brother, I do. But my question centered around the question of how best to CLEAN my radiator...I simply assumed that the manual wouldn't deal with which brands of cleaner would be best, so did not refer to my manual at all, as you correctly inferred.
Old Apr 5, 2007 | 09:15 AM
4MySwee's Avatar
Ouch, a little lively debate eh?
My point still stands. It isn't printed in my service booklet!!!! (Not for my tranny anyway). That booklet is what I use to follow correct servicing guidelines. Those are according to Nisssan's standards.
Also Lobewiper,
I agree with your point. I'm not too certain that the Service booklets with our cars tell us how to clean the radiator.
Old Apr 5, 2007 | 10:30 AM
Stardust's Avatar
F---ing Kangaroos
Are you that lazy that you can't open your OWNERS MANUAL?
Old Apr 5, 2007 | 02:32 PM
I VIK I's Avatar
Sometimes its simply good to have a opinion? Theres alot of **** in the owners manual you don't do, Like when it says to change your cabin filter, Do you do that exactly like it tells you to? Probably not therefore I just wanted a opinoin from someone who seemed like they knew there stuff on these things therefore I asked? I don't understand why its such a pain in the *** to answer one simple question?
Old Apr 5, 2007 | 05:11 PM
Stardust's Avatar
F---ing Kangaroos
You didn't answer mine
Are you really that lazy?
BTW: It takes less energy to open your f'ing owners manual then it does to ask a stupid question here.
Old Apr 7, 2007 | 11:56 AM
madmik's Avatar
How often you change the antifreeze depends on usage (severe or normal) and if you are obsessed like me and replace it every two years. The real test is a PH test. The illusive drain valve is under the rad, next to the lower rad hose, and requires a philips head screwdriver. Hold about 7 quarts since some is left in the block.
For general info, recall, specs on the MAX go to:
http://www.nissanhelp.com
For help on how to maintain your car:
http://www.nissanhelp.com/Ownership/Maxima/Diagnose.htm
For a full set of service manuals, goto:
http://www.phatg20.net/modules.php?n...ownload&cid=73
Get winrar to extract the PDF's.
For a PDF version of the owner's manual, goto:
http://www.nissan-techinfo.com/nissa...p?dept%5Fid=37
May the force be with you.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
