Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
My MPG goes down after every oil change
Old Jul 23, 2007 | 08:10 AM
PhillyMAx's Avatar
Weird. I change my oil pretty often (every 4000 miles, which lasts me < 3 months). After each time, my MPG goes from approx 26 down to 21. It gradually increases as the weeks go by, but when it comes time to change the oil again - same problem.
Nothing different in my oil changes. New OEM filter everytime and Mobil 5w30. Anyone else experience this?
Old Jul 23, 2007 | 08:47 AM
mikekantor's Avatar
Is it possible that you drive a bit harder, knowing that you have fresh oil? I can think of any other reasonable explanation.
Old Jul 23, 2007 | 11:12 AM
andrei3333's Avatar
no, unless u had some weird oil in there that was not energy conservant, i duno
Old Jul 24, 2007 | 09:13 AM
A33Black's Avatar
That sometimes happens to me too. I get the best gas mileage towards the end of my 5K interval.
Old Jul 24, 2007 | 09:48 AM
CCS2k1Max's Avatar
Wild guess, sheared down and/or fuel diluted oil into the 20w range.
Old Jul 26, 2007 | 05:56 AM
PhillyMAx's Avatar
A family friend is my mechanic, so he wouldn't do anything as petty as diluting the oil.
I've tried this out for the past 15 months, which consisted of about 4 or 5 oil chianges. Almost everything is consistent:
1. gas (super 93) from BP, across the street from work
2. same Mobil 1 oil, new OEM filter during every change
3. records taken only during normal driving (spirited driving occasionally, but I don't measure MPG for that tank)
4. car is only driven back and forth to work 60 miles/day (weekends is a different car)
Just changed my oil last Wednesday, filled up last Thursday. Got 21 MPG for that tank.
Old Jul 27, 2007 | 06:59 AM
CCS2k1Max's Avatar
Dude, don't hurt yourself. Don't show this thread to your trusted family friend mechanic. He may take you for a ride next time you visit him.
Hint: fuel dilution happens in the cylinders during combustion, not during an oil change...
Old Aug 9, 2007 | 03:36 PM
K20z1_rsx's Avatar
Asumption:
As soon as you change the oil you are topped off on oil. As the car is being driven for 3000-5000 miles oil is burned & consumed (many cars can use up to 1-2 quarts between oil changes) less oil for the crank to splash though less resistance on the motor better fuel the farther you get from new oil changes.
Old Aug 9, 2007 | 06:27 PM
mikekantor's Avatar
Because I had an 92 galant that burnt oil like mad and even that would never amount to 1-2 quarts. If the oil gets down that low in a V6, you're in trouble.
Also, lubrication gets worse with oil age, so MPG would go down in 3000-5000 miles.
Old Aug 10, 2007 | 07:07 AM
K20z1_rsx's Avatar
Really,
My brother bought a sentra se-r from a friend of ours after is was wrecked. I was over there one day when my buddy was changing the oil a he took the drain plug out and about a quart of oil came out total between the oil filter and drain plug. The oil light never came on him while driving before the oil change. After my brother bought the car we put the an SR20DET in the car and torn down the old motor that ran on less than 1 quart of oil (many times). To our surprise there was NO damage any where the motor ran great when we took it out it had around 179,000 miles on it.
Most cars will not be hurt running 1 quart low on oil.
Old Aug 10, 2007 | 07:51 AM
mikekantor's Avatar
I4 and V6 have approximately similar oil capacity. According to you I can cut my oil costs by around 75% by only using 1 quart of oil in my engine. You cant be serious.
Old Aug 10, 2007 | 01:52 PM
K20z1_rsx's Avatar
Ya sure let try it on your car first. No I don't advise running 1 quart of oil.
Yes some I4 hold as much oil as v6. My RSX-S holds a little over 5 quarts and every v6 I have ever worked on held between 4.5-6 quarts.
(Yes a 2001 Impala 3.8 V6 holds 4.5 quarts of oil)
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
