quick oil question!
Maxima.org Sponsor and Donating Maxima.org Member
If you drained the oil and changed the filter as you say you did (and I'm sure you did) it can't be overfilled with 4-qts, unless the car was seriously unlevel and you didn't drain all the old oil out. The dipsticks sometimes give goofy readings. Make sure you have the stick inserted the right way and check it again. Wipe the dipstick clean with a towel the first time you pull it, then check it again. And of course the car has to be level to get an accurate reading.
I disagree with this.
After running your engine for a few miles, you should check the dipstick following Talkinghorse's advice. I also like to let the oil settle in the engine, so I check my oil in the morning before I start the engine. Add more oil based on that dipstick reading.
In my case I have to put more motor oil in my Max than the "spec says" because the oil filter I use is larger than the Nissan filter.
if you change the oil and filter with the specified oil and filter recommendations then 4 1/2 quarts should be fine, if your gonna switch to a bigger filter and put less oil in thats just no common sense.
To check the oil Nissan says to check it on a cold engine, the FSM even says that.
I use 5 quarts with an M1-110, the M1-110 was by accident cause they had no 108 and I just looked at the diameter not the length
My point is "why blindly put in a certain abount of motor oil." Put in enough to get the oil to the end of the dipstick and then add enough oil to get to the full line on the stick. Then you absolutely know that you have the correct amount of motor oil in your engine. The difference between the two marks on the dipstick is essentially 1 liter or almost 1 quart of oil.
What you don't want is too much oil in the engine. Doing it my way, you substantially reduce the chance of overfilling your engine.
It is much worse to overfill you oil pan by 1/2 a quart than to underfill it by the same amount. You can do real damage to your engine by overfilling, and essentially no damage by underfilling. So check the dipstick to be certain that you did not overfill her.
We measured out the exact amount of oil as per the manual, and put that in, and my dip stick still shows that it's overfilled?
I have never heard of a "dipstick going wrong" -- but I suppose it could happen. However, given the difference between slightly overfilling and slightly underfilling your engine, I would tend to believe the dipstick reading and not put in so much motor oil. Thus, by following the dipstick you, in fact, end up slightly underfilled, you will certainly be better off than putting in the spec amount and, in fact, ending up slightly overfilled.
How much oil did you put in, and what filter are you using?
kjlouis
Oct 3, 2015 05:29 AM
dvcamp
Sep 18, 2015 10:17 AM
sdotcarter
Sep 2, 2015 09:53 PM
