Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Transmision fluid level?
Old Apr 29, 2008 | 11:15 PM
jimmypronet's Avatar
OK i found the sticky in changing transmision fuid (automatic) .... my question now is.. i got a 04 max... how many quarts should i put after i cleaned and drain it.. and where will i see the level?
Old Apr 30, 2008 | 05:01 AM
MichMaxFan's Avatar
You will most likely be putting in the exact amount that you took out. In my case, however, some moron had overfilled it and I didn't know it and when I drained and put back what I took out, it was too high on the dipstick.
So, what I would do if I were you is measure what came out and if it was lets say 4.5 qts then maybe put in 3.5 or so and then the final amt just do a little at a time until it measures in the cool section on the stick (you then know it's atleast on the stick). Then start the car and run according to user's manual and gradually add the fluid and keep monitoring the level until it measures appropriately on the dipstick. IF you had checked the level before changing it, then you would be fine just to put back the same amt you took out. In my case, I "assumed" is was right because a trans shop had done it the time before and I was wrong because it was overfilled.
Hope this helps. Read the sticky you found, it will help a lot.
mclasser
22
Nov 12, 2020 01:58 PM
Need help
23
Oct 2, 2015 08:56 AM
sliptap
Sep 30, 2015 05:57 AM
