Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
1997 maxima 5sp manual transmission drain plug stuck
Old Jun 7, 2008 | 12:13 PM
modenaf1's Avatar
Is there any way to get a socket around this bolt? Nobody in town sells 12mm 6 point wrenches anymore, I tried with a 12point wrench and stripped it just a little bit. What is that metal bracket thing that is right in front of the drain bolt is there any way to remove that?
-Nick
Old Jun 18, 2008 | 02:26 PM
goldtooth's Avatar
Just pop out the black switch (Neutral/ Reverse switch) that is located along the bottom and all the fluid will come out almost instantly. No need to undo that stuck bolt.
MikesChevelle
Mar 2, 2021 11:32 AM
Finkle
Sep 27, 2015 09:53 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
