Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
coolant flush,transmission flush, and oil change
Old Aug 10, 2014 | 08:51 PM
thomas512atx's Avatar
Hi, Im looking for a site or some instructions on how to do a oil change,transmission fluid flush, and coolant flush on my 2010 Maxima. Does anyone have this information? Ive had my car for 4 years and im going to try this for the 1st time. I tried searching this site but I couldnt find anything. Any help would be greatly appreciated. Thanks in advance.
Old Aug 10, 2014 | 09:00 PM
chrome91's Avatar
oil change just remove the oil pan drain plug, drain the oil, tighten plug, remove old oil filter, put on new filter, fill with oil, done
coolant just loosen the drain **** on the radiator, drain out the coolant, tighten the ****, fill with new coolant, run the car with the rad cap off until the air bubbles quit coming out and the thermostat opens
trans being a CVT i would only get it serviced by the dealer, wouldnt want to do it yourself
Old Aug 11, 2014 | 08:51 AM
Thanks Ill do that for the transmission fluid. Is the radiator plug accessible without removing any panels or does a panel have to be removed like the oil filter?
Old Aug 11, 2014 | 11:48 AM
Nevermind I found it.
Old Jul 12, 2021 | 05:33 PM
Vinar's Avatar
You can easily do a drain and fill on the CVT.
Just remove the drain bolt and make sure you measure all that comes out. Usually 4.5 quarts.
Then just add in 4.5 quarts of fresh CVT fluid.
Takes about 30 mins not much harder than an oil change.
sctludwig
Sep 1, 2022 01:32 PM
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
kjlouis
Oct 3, 2015 05:29 AM
sdotcarter
Sep 2, 2015 09:53 PM
