Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
How many liters of CVT fluid? 2014 Maxima
Old Dec 29, 2023 | 01:20 PM
Rafa_V's Avatar
How many liters of NS2 fluid are needed to perform an oil change on the CVT transmission of a 2014 Maxima 3.5L?
Old Dec 29, 2023 | 05:30 PM
LtLeary's Avatar
Drain and fill, about 4 to 4.5 depending on wether you replace the external filter. Remember to measure how much you drained and add the same back in
. Warm up to temp and then on level surface measure your fluid level. A hint here. If you replaced the inline filter by the drivers front wheel, iuse a white paper tile to hold the tip of the dipstick as the fluid will be a lot more clear and checking against a dark background (such as a shop towel) makes it hard to see
HadMatter2014
Aug 31, 2024 09:20 AM
Legionnaire1856
Jan 28, 2019 10:12 AM
heynow
Mar 8, 2007 09:29 PM
heynow
Feb 7, 2007 06:47 AM
